The best fidget toy around! Make the bongo cat tap away your troubles with the clicky satisfaction of a kailh jade mechanical switch!
Features
- Tap counter with automatic saving to persistent memory
- Tap speed measurement
- Two display color modes (normal and inverted)
- Optional overlay display
Instructions:
Power
- Requires a single CR2032 battery (positive side up)
In-Use Controls
- Hold the left button to invert the display color
- Hold both buttons to enable or disable the overlay
Power-On Modes
- Hold the right button while powering on to enter reset mode (an additional press is required to confirm)
- Hold both buttons while powering on to display the credits
Gallery
Afonso Muralha
Circat
alleycat
will.sweatman
deʃhipu
Hello, thank you for your interest in my project. The Gerbers you're looking for are here: https://github.com/afonsus1997/Bongo-Cat-Fidget-Toy/tree/main/Hardware/Bongo-Cat-Fidget-Toy/production
As for the screen, it's these ones (1.3inch): https://a.aliexpress.com/_EIlSnMa
Have fun building your bongo cat! If you have any more questions, feel free to reach ou!
