Why Build a Micro-Ohmmeter?
A project log for LysVolt MicroOhm - 4-wire precision ohmmeter
USB 4-wire micro-ohmmeter made in France for precise low-resistance measurements up to 100 mΩ with 2 µΩ resolution
dorian-covesDorian Coves 07/30/2025 at 15:220 Comments
This whole project started with a phone call from a friend who designs custom industrial machines:
- Hey Dorian, I need to measure how the electrical resistance of automotive connectors changes as they get mated and unmated thousands of times. Is that something easy to do?
- Well… that depends on what resistance values we’re talking about.
- Around 60 micro-ohms.
- And what’s your budget?
- Under €1000 ... for the whole electronics part of the test bench... and everything has to fit in something the size of a shoebox.
At that point, I couldn’t help but laugh.
When I started looking into it, I realized I couldn’t find any instrument that could:
The closest solution I found was to cobble something together using a programmable lab power supply and a bench multimeter in a 4-wire setup, all controlled by a PC.
With decent Siglent gear that would have cost around:
So about €600 per measurement channel, and that’s just for the instruments — not exactly compact or budget-friendly.
And that’s when I decided to build my own tool.
In the next logs, I’ll dive into why measuring such low resistances is tricky, and show the open‑source design that kick‑started this project.
