SigCore UC Source Code Now Public on GitHub
A project log for SigCore UC - Universal Controller
Universal industrial I/O controller with relays, analog/digital I/O, Modbus & OPC-UA support. Powered by Raspberry Pi.
edwardEdward • 12/04/2025 at 05:38•0 Comments
The SigCore UC repo is now officially live on GitHub.
GitHub Repository
This is the full codebase for the SigCore UC platform — firmware, server, Control Panel application, drivers, update tools, and all the supporting hardware documentation. If you wanted to dig into how this thing actually works behind the panels, it’s all there now.
A quick breakdown of what’s in the repo:
The repo’s still marked as early-stage (revA hardware, pre-production software), but everything is functional and running on the current prototype boards. As work continues, all updates will push directly to GitHub so the history stays transparent.
What’s next?
If you’ve been following along and wanted to see “under the hood,” now’s the time. Feedback, issue reports, forks — all welcome.
SigCore UC is built to be both powerful and open, so making the repo public is a big step toward that.
