Supercharging ROS 2 Camera Performance on Pi 5: From 1.7 Hz to 30 Hz
A project log for GestureBot - Computer Vision Robot
A mobile robot that responds to human gestures, facial expressions using real-time pose estimation and gesture recognition & intuitive HRI
vipin-mVipin M 08/04/2025 at 05:580 Comments
While developing a ROS 2-based gesture-controlled robot on a Raspberry Pi 5, I encountered a major bottleneck: the camera node was publishing at an unusable 1.7 Hz, making any form of real-time perception infeasible. After a detailed system analysis and targeted optimizations, I achieved a 17x performance increase—reaching a stable 30 Hz with low-latency image delivery.
Hardware & Software Configuration
According to rpicam-hello --list-cameras, the IMX219 supports up to 103.33 fps at 640x480. However, ROS 2 was far from utilizing this potential.
Performance Baseline
This was unacceptable for real-time robotics.
Root Cause Analysis
Kernel Mode Setting (KMS) Configuration
The /boot/firmware/config.txt contained:
disable_fw_kms_setup=1
dtoverlay=vc4-fkms-v3d
disable_fw_kms_setup=1 blocks proper GPU setup. While Raspberry Pi OS prefers full KMS (vc4-kms-v3d), on Ubuntu 24.04 with Pi 5, fake KMS (vc4-fkms-v3d) provides better compatibility. Attempting full KMS caused kernel instability.
Reconfiguration Fix
Changes made:
Ensured:
Post-reboot, this restored GPU access and stabilized image acquisition.
ROS 2 Camera Node Optimization
Pixel Format
The default node was selecting XRGB8888, which carries a high memory and bandwidth cost. Switching to YUYV reduced transfer size and improved throughput significantly.
Launch Parameters
buffer_queue_size: 2
use_intra_process_comms: true
exposure_time: 33000
frame_rate: 30.0
jpeg_quality: 80
These settings minimized latency, stabilized frame delivery, and aligned image acquisition with the camera's physical capabilities.
System-Level Tuning
CPU Frequency Scaling
To prevent CPU throttling during peak loads, I forced the performance governor:
sudo apt install cpufrequtils
echo "GOVERNOR=performance" | sudo tee /etc/default/cpufrequtils
This kept CPU frequency at maximum for consistent ROS node execution.
Composable Nodes
Switching from separate ROS nodes to a composable container significantly reduced IPC overhead. This helped eliminate minor jitter during image transport and ensured tight timing control.
Performance Results
MetricBeforeAfterImprovement
Raw Image Rate1.7 Hz28 Hz16.5×
Compressed Rate1.8 Hz30 Hz16.7×
Avg. Latency600 ms35 ms17×
CPU GovernorondemandperformanceOptimized
Troubleshooting Notes
