Improved webinterface, the device status page now shows key information. Now, the temperature of the pico cpu can be read out - and you can check if your microcontroller (or the realtime clock) is running hot, or if the cpu is running out of memory. There is also useful information to use and configure the device. More at casparlab.eu
caspar
