1. Unboxing Contents:
Issue: Internal packaging is very detailed, but the outer carton is too soft, risking hardware damage.
2. Environment Setup
Using VScode for compilation. Refer to: “Beginner Guide: Setting up AiPi-R2 Windows Environment” on Ai-Thinker Forum.
Encountered issue during compilation:
Fix: Open aithinker_Ai-M6X_SDK\project.build, comment out lines 75 and 76 by adding # at the beginning and save.
#        cp $(BL_SDK_BASE)/bsp/board/bl616dk/config/edata.bin build/build_out
#        cp $(BL_SDK_BASE)/bsp/board/bl616dk/config/Rx_boot2_m61.bin build/build_out
3. Example Testing
No onboard LED (recommended to add one), making it hard to verify board operation without a display.
LVGL Demo: Reflashed official LVGL example using make for compilation and make flash COMX=COM3 for flashing (COM3 is USB-TTL port).
Re-burn the LVGL official routines. Use make to compile the code and make flash COMX=COM3 to burn it. COM3 is the port currently connected to the development board. Use USB to TTL. The connection diagram is as follows:
4. LVGL Integration & Testing
LVGL was customized based on the AiPi-Eyes-Rx example. After GUI design using GuiGuider, generate and replace the generated folder under demos\ai_lvgl\src\generated.
5. SPI TF Card Reading & FATFS Filesystem
Wired the onboard SPI to a TF card module (or solder a TF slot). Adjust pin definitions accordingly.
Key SPI code: Refer to
aithinker_Ai-M6X_SDK\examples\peripherals\spi\spi_poll,SPI configuration and TF card initialization code included in the document.
void spi_isr(int irq, void *arg)
    uint32_t intstatus = bflb_spi_get_intstatus(spi0);
    if (intstatus & SPI_INTSTS_TC) {
        bflb_spi_int_clear(spi0, SPI_INTCLR_TC);
        //printf("tc done\r\n");
        spi_tc_done_count++;
    if (intstatus & SPI_INTSTS_TX_FIFO) {
        //printf("tx fifo\r\n");
    if (intstatus & SPI_INTSTS_RX_FIFO) {
        //printf("rx fifo\r\n");
void SPI_init(u32 freqm)
    struct bflb_spi_config_s spi_cfg =
#if (SPI_CASE_SELECT == SPI_MASTER_CASE)
        .freq = freqm,
        .role = SPI_ROLE_MASTER,
#else
        .freq = 32 * 1000 * 1000,
        .role = SPI_ROLE_SLAVE,
#endif
        .mode = SPI_MODE3,
        .data_width = SPI_DATA_WIDTH_8BIT,
        .bit_order = SPI_BIT_MSB,
        .byte_order = SPI_BYTE_LSB,
        .tx_fifo_threshold = 0,
        .rx_fifo_threshold = 0,
    spi0 = bflb_device_get_by_name("spi0");
    bflb_spi_init(spi0, &spi_cfg);
    bflb_spi_tcint_mask(spi0, false);
    bflb_irq_attach(spi0->irq_num, spi_isr, NULL);
    bflb_irq_enable(spi0->irq_num);
    bflb_spi_feature_control(spi0, SPI_CMD_SET_CS_INTERVAL, 0);
// Modify board.h and add the following:
void board_spi0_gpio_init()
    struct bflb_device_s* gpio;
    gpio = bflb_device_get_by_name("gpio");
    // spi cs
    bflb_gpio_init(gpio, GPIO_PIN_20, GPIO_FUNC_SPI0 | GPIO_ALTERNATE | GPIO_PULLUP | GPIO_SMT_EN | GPIO_DRV_1);
    // spi clk
    bflb_gpio_init(gpio, GPIO_PIN_17, GPIO_FUNC_SPI0 | GPIO_ALTERNATE | GPIO_PULLUP | GPIO_SMT_EN | GPIO_DRV_1);
    // spi miso
    bflb_gpio_init(gpio, GPIO_PIN_22, GPIO_FUNC_SPI0 | GPIO_ALTERNATE | GPIO_PULLUP | GPIO_SMT_EN | GPIO_DRV_1);
    // spi mosi
    bflb_gpio_init(gpio, GPIO_PIN_15, GPIO_FUNC_SPI0 | GPIO_ALTERNATE | GPIO_PULLUP | GPIO_SMT_EN | GPIO_DRV_1);
// Below is the SPI initialization and SD card read code:
u8 SD_Initialize(void)
    u8 r1; // Response from SD card
    u16 retry; // Retry counter
    u8 buf[4];
    u16 i;
    SPI_init(281000); // Set to low speed
    SD_DisSelect();
    for(i=0;i<10;i++)
        SD_SPI_ReadWriteByte(0XFF); // Send at least 74 clock cycles
    retry=20;
    do
        r1=SD_SendCmd(CMD0,0,0x95); // Enter IDLE state
    } while((r1!=0X01) && retry--);
    SD_DisSelect();
    SD_Type=0; // Default: no card detected
    if(r1==0X01)
        r1=SD_SendCmd(CMD8,0x1AA,0x87);
        if(r1==1)
            for(i=0;i<4;i++)
                buf[i]=SD_SPI_ReadWriteByte(0xFF);
            SD_DisSelect();
            if(buf[2]==0X01&&buf[3]==0XAA)
                retry=0XFFFE;
                do
                    r1=SD_SendCmd(CMD55,0,0x01); // Send CMD55
                    r1=SD_SendCmd(0x69,0x40000000,0x01); // Send CMD41
                    SD_DisSelect();
                } while(r1&&retry--);
                if(retry && SD_SendCmd(CMD58,0,0X01)==0)
                    for(i=0;i<4;i++)
                    SD_DisSelect();
                    if(buf[0]&0x40)
                        SD_Type=SD_TYPE_V2HC;
                    else
                        SD_Type=SD_TYPE_V2;
        else // SD V1.x / MMC V3
            SD_SendCmd(CMD55,0,0X01);
            r1=SD_SendCmd(CMD41,0,0X01);
            SD_DisSelect();
            if(r1<=1)
                SD_Type=SD_TYPE_V1;
                retry=0XFFFE;
                do
                    SD_DisSelect();
            else // MMC card does not support CMD55+CMD41
                SD_Type=SD_TYPE_MMC;
                retry=0XFFFE;
                do
                    r1=SD_SendCmd(CMD1,0,0X01);
                    SD_DisSelect();
            r1=SD_SendCmd(CMD16,512,0X01);
            SD_DisSelect();
            if(retry==0 || r1!=0)
                SD_Type=SD_TYPE_ERR;
    SD_DisSelect();
    SPI_init(16000000); // Switch to high speed
    if(SD_Type)
        return 0;
    else if(r1)
        return r1;
    return 0xaa; // Other error
u8 SD_SPI_ReadWriteByte(u8 data)
    u8 retnum;
    Spi_Send_Read_Data_Arr(&data, &retnum, 1);
    return retnum;
void SD_DisSelect(void)
    SD_SPI_ReadWriteByte(0XFF); // Send 8 extra clock cycles
u8 SD_WaitReady(void)
    u32 t = 0;
    u8 rStr = 0;
    do
        rStr = SD_SPI_ReadWriteByte(0xFF);
        if(rStr == 0XFF)
            return 0; // Ready
        t++;
    } while(t < 0XFFFFFF);
    return 1; // Timeout
u8 SD_Select(void)
    if(SD_WaitReady() == 0)
        return 0; // Ready
    SD_DisSelect();
    return 1; // Failed
u8 SD_SendCmd(u8 cmd, u32 arg, u8 crc)
    u8 r1;
    u8 Retry = 0;
    SD_DisSelect();
    if(SD_Select()) return 0XFF; // Select failed
    SD_SPI_ReadWriteByte(cmd | 0x40);
    SD_SPI_ReadWriteByte((u8)(arg >> 24));
    SD_SPI_ReadWriteByte((u8)(arg >> 16));
    SD_SPI_ReadWriteByte((u8)(arg >> 8));
    SD_SPI_ReadWriteByte((u8)(arg));
    SD_SPI_ReadWriteByte(crc);
    if(cmd == 12)
        SD_SPI_ReadWriteByte(0xff); // Dummy byte for CMD12
    Retry = 0X1F;
    do
        r1 = SD_SPI_ReadWriteByte(0xFF);
    } while((r1 & 0X80) && Retry--);
    return r1;
If you have the system time, you can enter it. If not, just use a random one.
Other files in the file system can be copied directly to the folder and used. The specific interface is as follows:
FRESULT f_open (FIL* fp, const TCHAR* path, BYTE mode);                                /* Open or create a file */
FRESULT f_close (FIL* fp);        /* Close an open file object */
FRESULT f_read (FIL* fp, void* buff, UINT btr, UINT* br);                        /* Read data from the file */
FRESULT f_write (FIL* fp, const void* buff, UINT btw, UINT* bw);        /* Write data to the file */
FRESULT f_lseek (FIL* fp, FSIZE_t ofs);        /* Move file pointer of the file object */
FRESULT f_truncate (FIL* fp);        /* Truncate the file */
FRESULT f_sync (FIL* fp);        /* Flush cached data of the writing file */
FRESULT f_opendir (DIR* dp, const TCHAR* path);                                                /* Open a directory */
FRESULT f_closedir (DIR* dp);        /* Close an open directory */
FRESULT f_readdir (DIR* dp, FILINFO* fno);                                                        /* Read a directory item */
FRESULT f_findfirst (DIR* dp, FILINFO* fno, const TCHAR* path, const TCHAR* pattern);        /* Find first file */
FRESULT f_findnext (DIR* dp, FILINFO* fno);                                                        /* Find next file */
FRESULT f_mkdir (const TCHAR* path);        /* Create a sub directory */
FRESULT f_unlink (const TCHAR* path);        /* Delete an existing file or directory */
FRESULT f_rename (const TCHAR* path_old, const TCHAR* path_new);        /* Rename/Move a file or directory */
FRESULT f_stat (const TCHAR* path, FILINFO* fno);                                        /* Get file status */
FRESULT f_chmod (const TCHAR* path, BYTE attr, BYTE mask);                        /* Change attribute of a file/dir */
FRESULT f_utime (const TCHAR* path, const FILINFO* fno);                        /* Change timestamp of a file/dir */
FRESULT f_chdir (const TCHAR* path);        /* Change current directory */
FRESULT f_chdrive (const TCHAR* path);        /* Change current drive */
FRESULT f_getcwd (TCHAR* buff, UINT len);                                                        /* Get current directory */
FRESULT f_getfree (const TCHAR* path, DWORD* nclst, FATFS** fatfs);        /* Get number of free clusters on the drive */
FRESULT f_getlabel (const TCHAR* path, TCHAR* label, DWORD* vsn);        /* Get volume label */
FRESULT f_setlabel (const TCHAR* label);                                                        /* Set volume label */
FRESULT f_forward (FIL* fp, UINT(*func)(const BYTE*,UINT), UINT btf, UINT* bf);        /* Forward data to the stream */
FRESULT f_expand (FIL* fp, FSIZE_t fsz, BYTE opt);                                        /* Allocate a contiguous block to the file */
FRESULT f_mount (FATFS* fs, const TCHAR* path, BYTE opt);                        /* Mount/Unmount a logical drive */
FRESULT f_mkfs (const TCHAR* path, const MKFS_PARM* opt, void* work, UINT len);        /* Create a FAT volume */
FRESULT f_fdisk (BYTE pdrv, const LBA_t ptbl[], void* work);                /* Divide a physical drive into some partitions */
FRESULT f_setcp (WORD cp);        /* Set current code page */
int f_putc (TCHAR c, FIL* fp);        /* Put a character to the file */
int f_puts (const TCHAR* str, FIL* cp);        /* Put a string to the file */
int f_printf (FIL* fp, const TCHAR* str, ...);                                                /* Put a formatted string to the file */
TCHAR* f_gets (TCHAR* buff, int len, FIL* fp);                                                /* Get a string from the file */
6. Wi-Fi Connection and TCP/IP Communication
For Wi-Fi connection initialization and connection code, refer to: aithinker_Ai-M6X_SDK\examples\wifi\sta\wifi_tcp. Key code to note:
uint8_t wifi_connect(char* ssid, char* passwd)
    int ret = 255;
    // struct fhost_vif_ip_addr_cfg ip_cfg = { 0 };
    uint32_t ipv4_addr = 0;
    scan_item_cb_t resd;
    char we1;
    char we2;
    if (NULL==ssid || 0==strlen(ssid)) {
        return 1;
    if (wifi_mgmr_sta_state_get() == 1) {
        wifi_sta_disconnect();
    printf("wait000");
    //wifi_mgmr_scan_ap_all(&we1,&we2,resd);
    if (wifi_sta_connect(ssid, passwd, NULL, NULL, 0, 0, 0, 1))
    //if (wifi_mgmr_sta_quickconnect(ssid, passwd,  0, 0))
        return 4;
    LOG_I("Wating wifi connet");
    //Wait for the connection to succeed
    sta_ConnectStatus = 0;
    for (int i = 0;i<10*30;i++) {
        vTaskDelay(100/portTICK_PERIOD_MS);
        switch (sta_ConnectStatus) {
            case CODE_WIFI_ON_MGMR_DONE:
                return 3;
            case CODE_WIFI_ON_SCAN_DONE:
                return 2;
            case CODE_WIFI_ON_DISCONNECT:        //Connection failed (the number of retries has exceeded but the connection is not successful)
                return 4;
            case CODE_WIFI_ON_CONNECTED:        //)Connection successful (when the Wi-Fi status is STA, it means that the IP (DHCP) is successfully obtained, or a static IP is used)
                LOG_I("Wating wifi connet OK");
                break;
            case CODE_WIFI_ON_GOT_IP:
                return 0;
            default:
                break;
    return 14; //Connection timeout
int wifi_start_firmware_task(void)
    LOG_I("Starting wifi ...");
    /* enable wifi clock */
    GLB_PER_Clock_UnGate(GLB_AHB_CLOCK_IP_WIFI_PHY | GLB_AHB_CLOCK_IP_WIFI_MAC_PHY | GLB_AHB_CLOCK_IP_WIFI_PLATFORM);
    GLB_AHB_MCU_Software_Reset(GLB_AHB_MCU_SW_WIFI);
    /* set ble controller EM Size */
    GLB_Set_EM_Sel(GLB_WRAM160KB_EM0KB);
    if (0 != rfparam_init(0, NULL, 0)) {
        LOG_I("PHY RF init failed!");
        return 0;
    LOG_I("PHY RF init success!");
    /* Enable wifi irq */
    extern void interrupt0_handler(void);
    bflb_irq_attach(WIFI_IRQn, (irq_callback)interrupt0_handler, NULL);
    bflb_irq_enable(WIFI_IRQn);
    xTaskCreate(wifi_main, (char*)"fw", WIFI_STACK_SIZE, NULL, TASK_PRIORITY_FW, &wifi_fw_task);
    return 0;
* @brief wifi event handler
*      WiFi Event callback
* @param code
void wifi_event_handler(uint32_t code)
    sta_ConnectStatus = code;
    BaseType_t xHigherPriorityTaskWoken;
    switch (code) {
        case CODE_WIFI_ON_INIT_DONE:
            LOG_I("[APP] [EVT] %s, CODE_WIFI_ON_INIT_DONE", __func__);
            wifi_mgmr_init(&conf);
        break;
            LOG_I("[APP] [EVT] %s, CODE_WIFI_ON_MGMR_DONE", __func__);
        break;
            wifi_mgmr_sta_scanlist();
            LOG_I("[APP] [EVT] %s, CODE_WIFI_ON_SCAN_DONE SSID numbles:%d", __func__, wifi_mgmr_sta_scanlist_nums_get());
        break;
            LOG_I("[APP] [EVT] %s, CODE_WIFI_ON_CONNECTED", __func__);
            void mm_sec_keydump();
            mm_sec_keydump();
        break;
            ui_load_scr_animation(&guider_ui, &guider_ui.screen_1, guider_ui.screen_1_del, &guider_ui.screen_del, setup_scr_screen_1, LV_SCR_LOAD_ANIM_OVER_LEFT, 0, 0, true, true);
            LOG_I("[APP] [EVT] %s, CODE_WIFI_ON_GOT_IP", __func__);
        break;
            LOG_I("[APP] [EVT] %s, CODE_WIFI_ON_DISCONNECT", __func__);
        break;
        case CODE_WIFI_ON_AP_STARTED:
            LOG_I("[APP] [EVT] %s, CODE_WIFI_ON_AP_STARTED", __func__);
        break;
        case CODE_WIFI_ON_AP_STOPPED:
            LOG_I("[APP] [EVT] %s, CODE_WIFI_ON_AP_STOPPED", __func__);
        break;
        case CODE_WIFI_ON_AP_STA_ADD:
            LOG_I("[APP] [EVT] [AP] [ADD] %lld", xTaskGetTickCount());
        break;
        case CODE_WIFI_ON_AP_STA_DEL:
            LOG_I("[APP] [EVT] [AP] [DEL] %lld", xTaskGetTickCount());
        break;
        default:
            LOG_I("[APP] [EVT] Unknown code %u ", code);
The calling method is as follows:
Start the thread in the main function
tcpip_init(NULL, NULL); wifi_start_firmware_task();
char * wifi_code;
                    char * wifi_name;
                    wifi_name = lv_textarea_get_text(guider_ui.screen_ta_1);
                    wifi_code = lv_textarea_get_text(guider_ui.screen_ta_2);
                    wifi_connect(wifi_name,wifi_code);
Here, we retrieve the Wi-Fi name and password from the text boxes on the LVGL screen.
The TCP/IP reference code is located in the same location as the Wi-Fi code. The key code is as follows:
void wifi_test_tcp_client_init(int argc, char **argv)
    abort_exec = shell_signal(SHELL_SIGINT, test_close_client);
    printf("tcp client task start ...\r\n");
    char *addr;
    char *port;
    struct sockaddr_in remote_addr;
    if (argc < 3) {
        printf("%s", PING_USAGE);
        return;
printf("111...\r\n");
    /* get address (argv[1] if present) */
    addr = "192.168.31.236";//argv[1];
    /* get port number (argv[2] if present) */
    port = "8888";//argv[2];
    while (1) {
        printf("222...\r\n");
        if ((sock_client = socket(AF_INET, SOCK_STREAM, 0)) < 0) {
            printf("TCP Client create socket error\r\n");
            return;
        printf("333...\r\n");
        remote_addr.sin_family = AF_INET;
        remote_addr.sin_port = htons(atoi(port));
        remote_addr.sin_addr.s_addr = inet_addr(addr);
        memset(&(remote_addr.sin_zero), 0, sizeof(remote_addr.sin_zero));
printf("444...\r\n");
        printf("Server ip Address : %s:%s\r\n", addr, port);
        if (connect(sock_client, (struct sockaddr *)&remote_addr, sizeof(struct sockaddr)) != 0) {
            printf("TCP client connect server falied!\r\n");
            closesocket(sock_client);
            return;
        printf("TCP client connect server success!\r\n");
        printf("Press CTRL-C to exit.\r\n");
        total_cnt = 0;
        while (1) {
            if (write(sock_client, send_buf, sizeof(send_buf)) < 0) {
                printf("write falied!\r\n");
                break;
            total_cnt += sizeof(send_buf);
            vTaskDelay(500);
        return;
Invocation:
7. Summary & Development Ideas
Current test results:
Future plans:
