The core of this project is do you cut the red wire or the blue wire? To complicate things there's also a flashing LED, so do you need to cut the wire when the LED is flashing on or flashing off?
So here's the four scenarios:
- Cut Wrong Wire, Wrong Time - Flasher Stops, Bombe detonates.
- Cut Wrong Wire, Right Time - Flasher Stops, Bombe detonates.
- Cut Right Wire, Wrong Time - Flasher Stops, Bombe detonates.
- Cut Right Wire, Right Time - Flasher Stops, Bombe Diffused!
Details of how the Logic Bombe was built are in the build instructions but if you just want to see how it works take a look at the video below:
Tom Goff
