Updated Files
A project log for SAOfinity
A modular, low barrier and inexpensive way to display all your SAOs Infinitely!
jeremygeppertjeremy.geppert 11/11/2025 at 23:340 Comments
V2 of the 3D printed files have been updated.
The pcb version is for the optional PCB
The non-pcb version will work with just an SAO connector and some proto-board.
V2 does away with the PCB snapping into place and relies on the longer clips to hold the board in place while also making the grid work much more solid.
