Design Objectives
A project log for StampPD - Up to 28V, 5A USB-C Power in a PCB Stamp
A PCB stamp to add 140W Power Delivery 3.1 (PD3.1) to any I2C capable microcontroller!
alec-probstAlec Probst 08/10/2025 at 01:380 Comments
Hi all!
This log is to define the goals for this project. I want to establish what the design objectives of the StampPCB will be.
Objectives
Inspiration
This project was inspired by the PicoPD. This board adds USB-C Power Delivery to a RP2040. Want variability in the USB-C PD just like this board.
The stamp design is inspired by the RP2350 Stamp. Want a drop in component just like this stamp.
Early Part Choice
Current part choices are influenced by the PicoPD. Want to upgrade from the AP33772 to the AP33772S for a more up to date PD spec (PD3.0 vs PD3.1). This allows for an increase from 100W (20V, 5A) to 140W (28V, 5A) as well as a couple other features. The downside is that there is less fine grain control of the voltage and amperage (20mV vs 100mV increments and 50mA vs 250mA increments)
Current Part Choice
Future Usage of StampPD
While StampPD is designed to be as microprocessor agnostic as I can make it, I do have a board I want to build with it in mind. That board currently uses the RP2350 Stamp with StampPD and a third USB-PD High Power GPIO Stamp to allow the RP2350 to control pins at the max power of StampPD. This project will come after StampPD is finished
