Component Choice Methodology
A project log for StampPD - Up to 28V, 5A USB-C Power in a PCB Stamp
A PCB stamp to add 140W Power Delivery 3.1 (PD3.1) to any I2C capable microcontroller!
alec-probstAlec Probst 09/12/2025 at 21:290 Comments
Hi all!
In this log I'm going to go over my methodology for component selection. I will explain what subsystems I want to include on StampPD, component requirements, other influencing factors, and a summary of component restrictions. In the next couple logs I will go over each sub-system of the board component by component to explain my part choices. I hope to show how I went about component selection to give new PCB designers an idea of how I approached this this design as well as receive feedback from more experienced designers. I have minimal experience with power design so I'm sure I've made mistakes somewhere here!
Board Subsystems
There are 5 main parts of StampPD:
These 5 parts are combined together to create the stamp. Only two of these sub-systems are absolutely necessary, the PCB and the USB PD Controller. The USB ESD Protection is nice to have but is optional. Being only a single component (TPD4E5U06DQAR) it would be easy to remove. The 5.0V and 3.3V Regulators are also nice to have but could be removed if needed.
Part Requirements
There are a couple requirements I've put on the design that influence what parts I want to select:
Other Influencing Factors
I have some personal external factors that also limit my part selection:
Summary of Component Restriction Decisions
Here is a summary of the restrictions that I have put on component selection:
Finally, here's the latest Schematic of the StampPD. In the next log I'll go over the 5.0V and 3.3V Voltage Regulator part selection on a component by component basis to explain how each component was chosen.
