2025-08-09
Created a 3D model for the rack and sent a 3-unit version to the printer. The print came out smoothly!
However, at a length of 29 cm, it only barely fit inside the printer (which works with a 256-mm cubic space). A 10-unit rack will be around a metre in length. I probably need to reconsider how this will be printed and assembled.
Ayu
