Assembly & bring-up
A project log for Drifting Pulses: Fire
Ever-changing loops of audiovisual pulses: (1) electronic oscillators
ayuAyu 08/20/2025 at 08:170 Comments
2025-08-18
The circuit boards have arrived! Large boards are way easier to handle than miniature ones like those for Wind.
  Steps of assembly: (1) empty circuit boards; (2) mounted components; (3) borrowing a component from another board; (4) plugged-in LED and speaker.
As I've lost track of my IMU stock, I had to borrow one from those previous assemblies (^ ^;)
The first-ever bring-up succeeded without friction. Both light and sound worked; the light at full intensity consumed around 150 mA at 3.3 V or 500 mA at 1.2 V (from a 1250-mAh AAA-sized NiMH battery).
Circuit powered by an AA battery, the LED emitting a red light.
Although light and sound do not appear to work well together: the light dims by a lot when sound turns on. This is due to the voltage drop at the DC-DC regulator with the surge of increased consumption. This has also been a quirk in Wind, but here the light is brighter and hence more noticeable. It remains to be seen whether mounting the bulk capacitor (C11) will resolve the issue.
In addition, there is a hissing noise from the speaker, supposedly due to noise in the filter. My analogue design capability is currently severely limited, so I think I should seek external consultancy on this.
The issues aside, I have found an ideal type of lampshades that perfectly manifests my original vision. Paired with the light, the outcome I'd happily call eye candy.
Box of four lamp shades. Each is a spherical shell with a circular opening.
Montage of a tabletop light changing colours: blue, red, green.
