Firefly
A Z80 Retrocomputing Development System.
A Z80 design of my own, though with inspiration from multiple sources. Goal was to correct shortcomings of a board I designed in '98 and give me an easily-extensible platform on which to run CP/M and tinker. It's modular in the spirit of an RC2014 but not requiring any modules at all for what I considered to be "core functionality", just omit undesired initial functionality as you populate the board and add it later if needed.
So far runs as expected and I'm coding away on a BIOS as time allows. If everything works to my satisfaction in the end I may offer some kits on Tindie if there's any interest and if I have time to make a Rev 2 board. This board has 2 bugs requiring 2 jumper wires -- a mis-sized footprint for the coaxial power connector, fixed by drilling, and a system clock trace net that got split into 2 separate nets by a KiCAD typo. There's also bit of physical placement tweaking I'd like to do for practicality.
But it runs like a champ! After the docs and BIOS are complete next up is a mass-storage module (CF or SDD) and getting CP/M on the beast.
DEVELOPMENT_HALT_202110.pdf
Notes mainly for me if I get a chance to pick this back up. Sharing here in case they're of sense to anyone interested.
Adobe Portable Document Format - 21.00 kB - 06/10/2022 at 15:39
Preview
wde8016_as_osh_park_ordered_20170212.tar.gz
Files as provided to OshPark for the main CPU board in the event they are of use to anyone. I've had to park the project for an indeterminate duration. Take and use anything you find of use. There are two bugs on this board, both of which were easily correctable. I think I've detailed them somewhere but if you can't find it or have any questions in general I will try and answer any questions. Good luck, have fun.
gzip - 14.48 MB - 06/10/2022 at 15:02
Download
ff_sd_card_spi_if_rev2.pdf
Schematic for current work-in-progress mass storage interface that's a step towards getting CP/M on the board. Ordered some protoboards today and will update as progress develops.
Adobe Portable Document Format - 148.28 kB - 07/13/2021 at 19:44
Preview
Nice rendering of the MicroSD SDHC SPI proto boards I ordered today from everybody's favorite purple prototyping place.
Portable Network Graphics (PNG) - 215.20 kB - 07/13/2021 at 19:43
Preview
ff1_gbr_main.lst
A listing of the current under-development firmware. Includes boot and memory management, core bios, general utilities, and system monitor. This software is operable, moderately tested, and under an iterative development/bug-fix process. The only known bugs at present stem from memory bounds wraparounds on the D(UMP) command.
lst - 190.98 kB - 02/15/2021 at 23:43
Download
View all 8 files
  • Protoboards ordered for MicroSD Storage
    William D. Ezell • 07/13/2021 at 19:54 • 0 comments
    Schematic and rendering uploaded a few minutes ago for my next step in hardware.  This will give me two MicroSD cards for persistent mass storage.  Normal operation will likely only use a single card (even the smallest of modern cards is more than CP/M can properly make use of).  Second card slot, however, is part of my goal to make the Firefly board entirely self-sufficient.  BIOS will include the ability to clone cards for backup.
    Still a long way to go before I'm ready to tackle CP/M.  Aside from coding BIOS support for managing the SD cards I've also got an Interrupt Mode 2 console handler to finish.
  • Source Code now on GitHub
    William D. Ezell • 05/04/2021 at 14:23 • 0 comments
    OK, got sidetracked a bit back in March picking up my Amateur Radio General Class license and being pulled into a few other side projects.  But the Firefly project will continue.  Next up will be a proper Interrupt Mode 2 handler for the serial console.  Right now everything is polled, which is not going to work very well once I add the planned mass storage and get into filesystem boggery.
    For now, first blog entry is to announce that all source code is publicly available (in a better form) on GitHub:
    Firefly Boot ROM and Monitor
    The code is
    • Tested to the extent that I have "worked on that area" of the board
    • Meant to be efficient where possible and practical but academic perfection was not allowed to get in the way of what I needed to do -- e.g., plenty of areas exist as "rainy-day" projects to come back and optimize
    • Mostly mine in authorship but several snippets were adapted and leveraged from other sources, the works of Lance Leventhal being a regular Go-To
    • Written in a style and within the constraints of tools appropriate to the era.  At some point I plan to get CP/M running on the board and migrate maintenance and development to legacy tools.  So that's why labels are short and cryptic.
    • Yours to use as you see fit
    Enjoy.  More updates soon (I hope).
    Bill
View all 2 project logs
Ed S wrote 07/30/2018 at 12:05 • point
Nice one! Perhaps @Lutetium will add it to the https://hackaday.io/list/2402-homebrew-computers list.
