After thinking about the 1 Hz challenge, I decided to build something that has been rattling around in my head for a while: an electromechanical oscillator.  I decided to adapt it into a basic, static 1Hz function generator that useses independent mechanisms to generate each waveform. I pared it down to only 2 functions (sine and square) when I noted the looming deadline.  The output is buffered and it is mostly accurate and could be used for any circuit that needs a slow function, like a blinky or a clock or even a eurorack maybe!?
The sine function is generated by a scotch yoke actuating a 10k ohm linear fader set up as a voltage divider.
The square function is generated by a cam actuating a mini switch.
This is a questionable piece of home-made test equipment that, in proper fashion, was designed as I went along.  I didn’t know what it was going to look like but I knew I wanted it to be sort of accurate, needlessly complicated, as mechanical as possible, and (most important) finished by the deadline.
Add a proj
