- Inverse kinematics of delta robots are actually simpler than those of arms
- Accuracy depends heavily on the play in various parts
- Some cheap servos have a lot of play -- I think even SG90 servos would have been better
- Ball joints can have some play too -- make sure to get ones with smaller balls
- Unused PCBs make great building material, if you just remember to add holes in your designs
- Having a bag of nuts and bolts in your drawer is great
- Paperclips can be soldered to PCBs and make great loops for bolting things to
- When figuring out kinematics, don't draw your robot in the neutral position
deʃhipu
