I have the basic code for the inverse kinematics of the robot working:
import math
from machine import I2C, Pin
import servo
PI2 = math.pi / 2
PI3 = math.pi / 3
class Robot:
ARM_LENGTH = 42
ROD_LENGTH = 134
HUB_LENGTH = 27
BASE_LENGTH = 62
BASE_X = (
0,
(BASE_LENGTH - HUB_LENGTH) * math.sin(2 * PI3),
(BASE_LENGTH - HUB_LENGTH) * math.sin(4 * PI3),
BASE_Y = (
BASE_LENGTH - HUB_LENGTH,
(BASE_LENGTH - HUB_LENGTH) * math.cos(2 * PI3),
(BASE_LENGTH - HUB_LENGTH) * math.cos(4 * PI3),
def __init__(self):
self.i2c = I2C(-1, Pin(5), Pin(4))
self.servos = servo.Servos(self.i2c, min_us=700, max_us=2400,
degrees=180)
self.trims = (0, -0.1, -0.2)
def home(self):
self.move(0, 0)
self.move(1, 0)
self.move(2, 0)
def move(self, arm, radians):
radians += self.trims[arm] + PI2
self.servos.position(arm, radians=radians)
def arm_ik(self, distance):
alpha = math.acos(
(self.BASE_LENGTH - self.HUB_LENGTH) /
(distance)
beta = math.acos(
(distance ** 2 + self.ARM_LENGTH ** 2 - self.ROD_LENGTH ** 2) /
(2 * self.ARM_LENGTH * distance)
return math.pi - alpha - beta
def robot_ik(self, x, y, z):
return tuple(math.sqrt(
(self.BASE_X[arm] - x) ** 2 +
(self.BASE_Y[arm] - y) ** 2 +
z ** 2
) for arm in (0, 1, 2))
def move_to(self, x, y, z):
for arm, distance in enumerate(self.robot_ik(x, y, z)):
self.move(arm, self.arm_ik(distance))
As you can see, shifting the servo by the width of the hub greatly simplified the equations. I am pretty happy with how it works -- managed to draw a circle on a piece of paper, and the circle is actually round. One thing is strange, though -- the circle was supposed to have 5cm radius, but it's around 2cm instead... I might have an error there somewhere. I will keep experimenting with it.
