Parts were designed in OpenSCAD, exported as STL and sliced using FlashForge's FlashPrint software using the "fine" settings (except for the pendulum mount for which precision wasn't important).
Parts were printed on a FlashForge Creator Pro (years old now).
The first armature had 7mm impulse faces which were way too wide.
| Part | Time to print | PLA filament (m) |
| escapement wheel | 03:51 | 8.74 |
| armature v1 (6mm thickness) | 01:17 | 3.3 |
| armature v2 (3mm thickness) | 00:53 | 2.13 |
| pendulum mount | 00:32 | 1.8 |
rkramer
