The 2 EPROM chips are connected to address LA0 to LA10 instead of LA1 to LA11 so I double the bytes instead of an ugly hardware patch. I use the 2 files BOOTEVEN and BOOTODD, but I doubled every bytes.
Still with this modification, the DIAG utility doesn't work.
Jacques Pelletier
