The DOTS & BOXES Game
34 years ago, I wrote a simple game to help my daughter with her understanding of Coordinate Geometry.
0 followers
X, Y coordinates - the basics of geometry.
Back in the early 1990's, my daughter was having a little difficulty with the concept. So, I did what any decent Dad would do, I wrote a simple game program to help her learn the basics.
Fast forward 34 years and I was cleaning out a very, very old hard drive and found the original source code! Kind of a WOW moment (wow as in surprising, not Windows On Windows.) Anyway, I compiled the source with QuickBasic64 and the resulting DOTS.EXE runs on Windows-11 64-bit unmodified.
The code attempts to be faithful to the basic rules:
- Select a COLUMN by selecting the X (ENTER)
- Select a ROW by selecting the Y (ENTER)
- Complete your selection by identifying the SIDE as A, B, C, D (ENTER)
The game progresses with YOU and the COMPUTER taking alternate turns. As the choices diminish, the game becomes more difficult and the number of open sides (those that do not close a box, become less numerous.) Eventually a box will have all 4 sides closed by either YOU or the COMPUTER and that box then gets counted on the scoreboard. Closing all 4 sides of a box entitles a free move.
The goal is to win by completing more boxes than the computer.
Good luck.
ONLINE RULES  DOTS and BOXES
CAVEATS: Depending on YOUR Windows security configuration,
- you may not be able to download the ZIP
- your Windows security may delete the dots.exe executable
- your Windows security may delete the dots.bas source code. Use dots.txt instead.
There are numerous solutions like adding an exception to the "Virus & threat protection settings", but I am not going to go into details because of the potential consequences of changing the default Windows security policies. YouTube and online discussions are easily found. See Gallery where I created a file exemption that provides the "Run anyways" choice.
If you are having difficulties, you can easily download the QB64 IDE and just run the downloadable dos.bas source code:  QB64 Here
dots.txt
Source code in notepad format
plain - 24.45 kB - 08/20/2025 at 18:33
Download
dots.zip
ZIP containing dots.exe
x-zip-compressed - 1.96 MB - 08/20/2025 at 18:16
Download
Dots.bas
Source Code
bas - 24.45 kB - 08/20/2025 at 15:37
Download
View all instructions
