Connectors
A project log for Modular Interface Exchange (ModIX) System
A modular electronics platform for programmable logic controller and other applications
benny-cheungBenny Cheung • 09/16/2025 at 14:41•10 Comments
The next question to consider is selecting a connector system for the project. For that, we have a lot of materials to start with. Let me list a few here.
There are tons of options available on the market. Just like creating a new standard, there are always pros and cons to selecting which system.
At the end of the day, the connector isn't just a plug—it's a promise of connectivity. Our main feature here is delivering a unified interface that handles I2C, SPI, UART, and GPIO without breaking a sweat. Why these? They're the Swiss Army knife of maker and industrial comms:
My current approach is to mix and match different systems: using Pmod (1.27mm pitch) for GPIO, Qwiic for I2C, and a 6x2 1.27mm pitch IDC connector for all SPI, I2C, and UART. Power will be using JST XH connector for a max of 3A power delivery. I guess this mostly covers all the use cases as illustrated in Pmod (but I don't understand why so many boards use SPI—maybe because of speed?). Coming up next, probably some real designs for your review. Stay tuned.
samuk wrote 09/17/2025 at 17:21 • point
There is a small  2mm pitch box header version of Mikroe you can use with https://www.mikroe.com/shuttle-click perhaps you could include that on your PCB?
UEXT is a similar (and older) concept https://www.olimex.com/Products/Modules/ including one of those would enable using these off the shelf open hardware modules https://www.olimex.com/Products/Modules/Interface/
Are the PCB JSON you shared EasyEDA? I didn't successfully open them yet
Benny Cheung wrote 09/23/2025 at 04:31 • point
Very nice suggestion. I think I will consider the UEXT connector. mikroBUS just seems odd to me to include analog input and PWM as they can be easily implemented by I2C IC.
I will fix the PCB JSON later. They suppose are EasyEDA readable but I have no idea what happened.
samuk wrote 09/23/2025 at 07:19 • point
Do you have a link to the EasyEDA project? I would be interested in having a look
samuk wrote 09/17/2025 at 17:06 • point
I see. What comms are you focusing on? I tried to default to RS486 but with Canbus or SPE as addons via a shield.
My Microcontroller stuff was based around https://www.olimex.com/Products/Duino/STM32/OLIMEXINO-STM32F3/open-source-hardware yes it's an old/ legacy footprint, but industrial rating counts for a lot in this space I think. On-board Canbus is nice too
I think it will be a more universal platform to cater for different communication method.
samuk wrote 09/17/2025 at 14:03 • point
I did  bit of digging into somewhat adjacent things and ended up with this https://github.com/samuk/IoT-Greenhouse-Temperature-and-Irrigation-Controller-Node-Red
Essentially a bunch of Olimex stuff on a custom carrier https://easyeda.com/editor#id=0fb0bc8a8a284d4f8c591254ed1418f7|7221dde35d414902bdfeba2d03370245|b370bd9c568b42909310514aeeca46e3|a863dc0108f74cb184ebf043b9bd98b7
So that it could work with hat rack https://plasmadan.com/product/hat-rack-mini-raspberry-pi-hat-mount/
And therefore the nice (but proprietary) https://sequentmicrosystems.com/
Benny Cheung wrote 09/17/2025 at 16:27 • point
Actually, I am developing a similar project and have come up with this idea. The concept is very nice, but you can achieve it on any kind of platform. However, once you complete the development and want to make it last long, it will present a different challenge.
samuk wrote 09/17/2025 at 17:00 • point
Indeed, that's why I've gone for the industrially rated Olimex components as the core, with the hot-swappable EMMC chip. It's not fully 'industrial' but somewhat more robust than a Pi for example.
samuk wrote 09/17/2025 at 13:55 • point
I'm curious why you decided to not use the Mikroe click?
Benny Cheung wrote 09/17/2025 at 16:20 • point
I think the concept of Mikroe is more oriented towards development tools, and the Click boards do not have standard dimensions. This creates significant difficulties in building an enclosure system around the platform. The stacking methodology is also not ideal for integration with casing. The two rows of headers also occupy quite a bit of space and make the board relatively large. I am thinking of a DIN rail casing scenario, and I definitely will update the logic here in a later log post.
There is also some attempt on what I am trying to acomplish as below but seems it is a bit unrefine:
https://www.hwhardsoft.de/english/projects/arduibox-feather/
