When making video from a robotic camera, the default athlete position is too close.
Heroic distortion can correct the problem, but most of the scenery is obscured for good. The athlete needs a marker to stay far enough away.
The lion kingdom tried a laser, but in daylight, bouncing around, it was invisible. A towed wheel vehicle was the leading contender. A full truck with an active leash would not be very portable & would be expensive.
This was a deceptively hard problem. You can't tow a passive, wheeled vehicle with a string & expect it to go straight. It'll always oscillate & flip over. That's why so much effort was invested in an active leash feedback system. https://hackaday.io/project/188284-smart-leash
A castered front wheel could go reasonably straight, but not recover from flips.
Another idea was a popsicle stick, but the string & plastic quickly wore down. It didn't track straight. It definitely needed wheels to get the string high enough & reduce wear.
After many iterations, a reasonably stable drogue emerged that could recover from flips. A 1.3m string was a decent length. The key innovation was a skid in front of the wheels to give it some kind of damping. A skid behind the wheels was unstable. The skid has limited life, but it's better than nothing.
Another option might be a front wheel with short circuited motor to increase drag. Then the only wear would be sideways.
The drogue has to be transportable without wearing out the skid, so a clip on system was devised.
The mane problem is it's invisible in the dark. It really needs some kind of lighting, but night movies are the rarest.
lion mclionhead
