According to this Instructable the thermometer's pins should connect to an Arduino like this:
- pin D (IR data) to pin 12
- pin C (IR clock) to pin 2
- pin V (IR power) to 3.3V power
- pin G (IR ground) to ground
Here's the sample code I tried first to get some measurements streaming in:
byte n = 0; // Interrupt Bit Count
volatile byte pos = 0; // Values Position Count
volatile byte values[5] = {
0,0,0,0,0}; // Values to be stored by sensor
byte cbit = 0; // Current bit read in
boolean irFlag = false; // Flag to indicate IR reading has been made
boolean ambFlag = false; // Flag to indicate ambient temp reading has been made
byte irValues[5] = {
0,0,0,0,0}; // Variable to store IR readings
byte ambValues[5] = {
0,0,0,0,0}; // Variable to store Ambient readings
const int len = 5; // Length of values array
const int clkPin = 2; // Pins
const int dataPin = 12;
const int actionPin = 5;
void setup(){
Serial.begin(9600);
pinMode(clkPin, INPUT); // Initialize pins
pinMode(dataPin, INPUT);
pinMode(actionPin, OUTPUT);
digitalWrite(clkPin, HIGH);
digitalWrite(dataPin, HIGH);
digitalWrite(actionPin, HIGH);
Serial.println("Type to Start..."); // Wait for input to start
while(!Serial.available());
Serial.println("Starting...");
Serial.println("IR (C), Ambient (C), Time Since Start (ms)");
attachInterrupt(1,tn9Data,FALLING); // Interrupt
digitalWrite(actionPin,LOW); // Make sensor start sending data
void loop(){
if(pos == len && values[0] == 0x4C){ // If sensor has sent IR packet...
for(int i = 0; i < len; i++){ // Store values to irValues
irValues[i] = values[i];
irFlag = true; // Indicate IR reading
pos = 0;
if(pos == len && values[0] == 0x66){ // If sensor has sent ambient packet...
for(int i = 0; i < len; i++){ // Store values to ambValues
ambValues[i] = values[i];
ambFlag = true; // Indicate Ambient reading
pos = 0;
if(pos == len && values[0] == 0x53){ // If sensor has sent junk packet
pos = 0;
if(irFlag && ambFlag){ // If successful IR and Ambient reading...
digitalWrite(actionPin,HIGH); // Make sensor stop sending data. Because Timing is weird, I want to ensure the interrupts do not happen during this section.
word tempword = 0; // Next 4 lines isolate temperature component of values
tempword = tempword | irValues[1];
tempword = tempword << 8;
tempword = tempword | irValues[2];
if(tn9Check(irValues)){ // If checksum is valid, print IR temperature
//Serial.print("IR = ");
Serial.print(int(tempword)/16.0 - 273.15);
Serial.print(", ");
else{ // If checksum isn't valid, print impossible temp
Serial.print("-273.15, ");
tempword = 0; // Isolate temperature component again for ambient
tempword = tempword | ambValues[1];
tempword = tempword | ambValues[2];
if(tn9Check(ambValues)){ // If checksum is valid, print ambient temperature
//Serial.print("Amb = ");
Serial.print("-273.15");
irFlag = false; // Reset flags
ambFlag = false;
Serial.print(", ");
Serial.println(millis()); // Print time for logging purposes
delay(2000); // Simulate other sensors or code
void tn9Data(){ // Interrupt Function
cbit = digitalRead(dataPin); // Read bit
if(pos >= len) pos = 0; // Keep index below 5
values[pos] = (values[pos] << 1) | cbit; // Store to values
n++; // Increment bit count
if(n == 8){ // Increment position count based on bits read in
pos++;
n = 0;
if(pos == len){ // If complete "packet" sent, stop sensor from sending
digitalWrite(actionPin,HIGH); // again until main loop allows it.
boolean tn9Check(byte tn9Values[]){ // Checksum calculating function
int mcheck = (int)tn9Values[0] + (int)tn9Values[1] + (int)tn9Values[2]; // Checksum calculation
int scheck = (int)tn9Values[3]; // Checksum sent by sensor
boolean crc = false; // Initialize return value
if(mcheck > 510) mcheck = mcheck - 512; // Handle sensor byte rollover
if(mcheck > 255) mcheck = mcheck - 256; // Handle sensor byte rollover
if(mcheck == scheck) crc = true; // Check checksum
return(crc); // Return
