The engine is air cooled and surrounded by tin. These parts are fairly thin. The largest part, and the one that drove the scale is the fan housing which can be printed on a standard 210x210mm printer. The underside of the tin is an aftermarket type that allows for an aftermarket header exhaust. Here are the parts.
And some completed pictures.
