Creating the 16V8 chips
A project log for Tatung Einstein Speculator analysis
It is a board that lets the Einstein computer emulate the Spectrum. Design by Tony Brewer.
keithKeith 10/31/2025 at 01:560 Comments
2025-10-30
The chips programmed successfully but failed verification.
I loaded the buffer with the created JEDEC files, then saved the buffer to files.
I read the programmed chips into the buffer, then saved the buffer to files.
I then ran diff to compare them. This is what I got:
1c1
<  Generated by Dataman-48 on Fri Oct 31 00:24:45 2025
>  Generated by Dataman-48 on Fri Oct 31 00:16:13 2025
68,74c68,74
< L002048 11000010*
< L002056 0000000000000000000000000000000000000000000000000000000000000000*
< L002120 11000010*
< L002128 0000000000000000110000001000000010000000100000000000000000000000*
< L002192 10*
< C1259*
< 2dea
\ No newline at end of file
> L002048 11111111*
> L002056 1111111111111111111111111111111111111111111111111111111111111111*
> L002120 11111111*
> L002128 1111111111111111111111111111111111111111111111111111111111111111*
> L002192 11*
> C23bd*
> 2ec6
and
1c1
<  Generated by Dataman-48 on Fri Oct 31 00:25:04 2025
>  Generated by Dataman-48 on Fri Oct 31 00:17:03 2025
68,74c68,74
< L002048 00000000*
< L002120 00000011*
< L002128 0000000000000000110000001111000010000000100000000000000000000000*
< L002192 10*
< C1ed7*
< 2e93
> L002048 11111111*
> L002120 11111111*
> L002192 11*
> C2ff3*
> 2f1a
I haven't found a fuse map for the GAL16V8CZ yet.
I retried programming with the Dataman set to device ATF16V8C, and the devices programmed and verified without problem.
The Z suffix relates to "zero power" mode parts. Perhaps Dataman did not get round to implementing those fuse bits?
