2025-10-30
The chips programmed successfully but failed verification.
I loaded the buffer with the created JEDEC files, then saved the buffer to files.
I read the programmed chips into the buffer, then saved the buffer to files.
I then ran diff to compare them. This is what I got:
1c1 < Generated by Dataman-48 on Fri Oct 31 00:24:45 2025 --- > Generated by Dataman-48 on Fri Oct 31 00:16:13 2025 68,74c68,74 < L002048 11000010* < L002056 0000000000000000000000000000000000000000000000000000000000000000* < L002120 11000010* < L002128 0000000000000000110000001000000010000000100000000000000000000000* < L002192 10* < C1259* < 2dea \ No newline at end of file --- > L002048 11111111* > L002056 1111111111111111111111111111111111111111111111111111111111111111* > L002120 11111111* > L002128 1111111111111111111111111111111111111111111111111111111111111111* > L002192 11* > C23bd* > 2ec6 \ No newline at end of file
and
1c1 < Generated by Dataman-48 on Fri Oct 31 00:25:04 2025 --- > Generated by Dataman-48 on Fri Oct 31 00:17:03 2025 68,74c68,74 < L002048 00000000* < L002056 0000000000000000000000000000000000000000000000000000000000000000* < L002120 00000011* < L002128 0000000000000000110000001111000010000000100000000000000000000000* < L002192 10* < C1ed7* < 2e93 \ No newline at end of file --- > L002048 11111111* > L002056 1111111111111111111111111111111111111111111111111111111111111111* > L002120 11111111* > L002128 1111111111111111111111111111111111111111111111111111111111111111* > L002192 11* > C2ff3* > 2f1a \ No newline at end of file
I haven't found a fuse map for the GAL16V8CZ yet.
I retried programming with the Dataman set to device ATF16V8C, and the devices programmed and verified without problem.
The Z suffix relates to "zero power" mode parts. Perhaps Dataman did not get round to implementing those fuse bits?
Keith
