ZORK/WISHBRINGER GLOWSTONE from INFOCOM CLASSIC
A glowing object that starts to glow when you shake it. Bouncing ball that lights up modified with glow in the dark paint and a UV light.
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
I wanted this frobozz stone that glows. The real zork stone glows when danger is near -Like a GRUE! and 8 bit tragedy GRUE may have been a truncated string variable. IE GRUESOME _____. From a time before graphics when game still exisited in this galaxy not so far away.
The stone glows because glow in the dark paint. I want to paint solar panels with this stuff. or have a glow shield at night. Or pool agitator.
This design entails Cutting a bouncing ball in half making it hollow and putting a battery led and spring so that when it is shook the UV LED lights the GLOW paint from interior. A mercury switch would be a bad Idea here.
Improvements would be a radiation detector. Then It would light up when you are in radiation. Like sunradiation.
Thanks to Infocom for that game Wishbringer I learned to read with. Also if you want to try Interactive Fiction Try Instead Engine on sourceforge. and contact me.
