v1.16 XW 04-05-2022
reorded: code
v1.15 XW 04-02-2021
reorded: source files
updated: SDD
v1.14 XW 14-08-2020
cleaned: code
v1.13 XW 07-08-2020
fixed: cpu usage too high (issue #30)
v1.12 XW 12-11-2019
fixed: run.sh
v1.11 XW 11-11-2019
added: OS and testOS
v1.10 XW 23-08-2019
added: syscalls (issue #11)
v1.9 XW 01-08-2019
changed: init memory size
v1.8 XW 30-07-2019
fixed: printf (issue #8)
fixed: missing zero_FastMemory.s file (issue #9)
v1.7 XW 29-07-2019
removed: unnecessary headers
added: return line after printf
v1.6 XW 28-07-2019
changed: start point to AI/AI
updated: Zero Java code
improved: run.sh
added: console out put at atomicvariable
removed: something
v1.5 XW 26-07-2019
fixed: loads multiple times (issue #5)
v1.4 XW 20-07-2019
fixed: naming COPY TO DOMAINZERO
v1.3 XW 18-07-2019
removed: kernel.dep in makefile
v1.2 XW 12-07-2019
removed: jdk and zero
moved: source code into src (issue #2)
v1.1 XW 08-07-2019
removed jx
v1.0 XW 05-07-2019
working
X. Wang
