Code
UART Receive Module
Converts the GP-01’s single-bit data into 8-bit data.
module uart_rx
parameter UART_BPS = 'd9600, // Baud rate
parameter CLK_FREQ = 'd50_000_000 // Clock frequency
input wire sys_clk , // System clock 50MHz
input wire sys_rst_n , // Global reset
input wire rx , // UART receive data
output reg [7:0] po_data , // 8-bit parallel output data
output reg po_flag // Data valid flag
//********************************************************************////****************** Parameter and Internal Signal *******************////********************************************************************////localparam define
localparam BAUD_CNT_MAX = CLK_FREQ/UART_BPS ;
//reg define
reg rx_reg1 ;
reg rx_reg2 ;
reg rx_reg3 ;
reg start_nedge ;
reg work_en ;
reg [12:0] baud_cnt ;
reg bit_flag ;
reg [3:0] bit_cnt ;
reg [7:0] rx_data ;
reg rx_flag ;
//********************************************************************////***************************** Main Code ****************************////***************************************
// Insert two-stage registers for data synchronization to eliminate metastability
// rx_reg1: First-stage register, reset to 1 when idle
always@(posedge sys_clk or negedge sys_rst_n)
if(sys_rst_n == 1'b0)
rx_reg1 <= 1'b1;
else
rx_reg1 <= rx;
// rx_reg2: Second-stage register, reset to 1 when idle
rx_reg2 <= 1'b1;
else
rx_reg2 <= rx_reg1;
// rx_reg3: Together with rx_reg2, forms the falling-edge detection
rx_reg3 <= 1'b1;
else
rx_reg3 <= rx_reg2;
// start_nedge: Generates a one-clock-cycle high pulse when a falling edge is detected
start_nedge <= 1'b0;
else if((~rx_reg2)...
Ai-Thinker
hasan kara
nqtronix
Piotr Gaczkowski
