Sensor fusion with Pi camera
A project log for Infrared Home Intrusion System
Thermal imaging with MLX90642 32x24 InfraRed (IR) array
Combining the IR array / thermal image with a Raspberry Pi camera module would be only a small step with the most recent prototypes.
It's not really necessary for the UseCase home intrusion detection, and it would not make much sense to use the prototype in the discussed IoT context anyway, for I could actually connect the IR array to the Raspberry Pi via I2C. It is an entirely new sort of application.
On a separate project page I might delve deeper into this topic (has been done before though, e.g. Raspberry Pi Thermal Imaging | Hackaday.io, let alone can easily be done with a Smartphone these days).
