MeowKit provides a secure, fully on-device Wi-Fi configuration workflow — no third-party tools or cloud services required. Users may enable the Wi-Fi setup mode from the system settings and complete the entire provisioning process locally on the device.
Key features:
Automatic Scan & Select — When Wi-Fi is enabled, MeowKit scans nearby access points and presents a sorted SSID list. Select the desired SSID directly from the device UI.
Integrated 2×5 Password Entry — Enter the network password using MeowKit’s unique nine-key (3×3) on-screen keypad. The compact keypad is optimized for quick, tactile entry on a pocket device while minimizing accidental input.
One-tap Connect — After entering the password, press Enter to initiate connection.
Real-time Status Feedback — The launcher displays immediate connection feedback: Connecting → Authenticated → Connected or a clear failure message with suggested next steps (retry, check password, or select another SSID).
Fully Local & Private — All scanning, authentication, and credential handling occur locally on the device. No external app, PC, or cloud account is required to provision Wi-Fi — preserving user privacy and reducing setup friction.
This workflow is designed for reliability and simplicity: scan, select SSID, enter password with the ergonomic 2×5 keypad, and receive an explicit success/failure result — all completed on MeowKit.
mingo.zhang
