What is the project about?
This project introduces a new physical measurement standard: the NKTm (noun form), for the NKTg Law (Law of Varying Inertia). It explores the theory, dimensional analysis, real-data verification (Neptune / NASA JPL Horizons), and real-world applications in astronomy, engineering, earth sciences, etc.
Why this project matters
Existing physics laws (Newton, Joule, Watt…) use well-defined units; NKTg introduces varying inertia, a quantity combining position, mass, velocity (and optionally rate of change of mass).
Having a standard unit (NKTm) helps quantify phenomena where mass varies explicitly (mass loss/gain, variable-mass systems).
Enables more accurate modelling, simulation, and understanding of dynamics in bodies like planets, spacecraft, robotics, environmental systems.
What will you do / What’s been done so far
Theoretical formulation of NKTg Law: two expressions
• NKTg₁ = x · p (position-momentum interaction)
• NKTg₂ = (dm/dt) · p (mass-variation momentum) -
Dimensional analysis to show how NKTm relates to standard dimensions: [M·L²/T] or [M²·L/T²] depending on form.
Verification using NASA JPL Horizons data for Neptune (2023-2024): computing NKTg₁, NKTg₂, total NKTg.
Identification of domains of application: astronomy, aerospace, environmental / earth sciences, engineering.
What remains to do
Build physical / computational models to simulate varying-mass systems using NKTm (e.g. spacecraft with fuel consumption, objects losing mass)
Create more case studies: e.g. real satellite data, meteor showers, biological systems (mass loss/growth)
Visualizations & plots to show behaviour over time
Possibly hardware / sensor experiments: tracking mass change, motion, measuring inertia variation
Publish code, diagrams, documentation, share open-source tools or libraries
Project details
Category: Theory + Computational / Modelling / Scientific project
Tags: physics, inertia, measurement, data-analysis, simulation, astronomy
Files / Docs: (You can include PDF of your theoretical write-up, data used, example scripts)
Components: if doing hardware / sensor work in future (mass sensors, motion tracking, etc.)
Build Instructions: For computational parts: what data sources, what tools (Python, MATLAB, etc.)
How you can contribute or follow
Feedback / critique on theoretical definitions, dimensional consistency
Help with modelling & simulation, visualization
Suggest case study datasets
Join as collaborator for any hardware builds or sensor-based measurement
Follow project logs for progress updates
Images / Media
Diagram showing NKTg₁ and NKTg₂ definitions and how they relate
Graphs of verification results vs. time or different celestial bodies
Any photos if hardware builds planned
What do I hope people will learn
Understand not only how to code / compute NKTg, but why each term exists, what physical meaning behind NKTm
See how measurement units can be extended for new physical laws
Be inspired to apply to unusual systems (variable mass, unusual inertia)
Nguyen Khanh Tung
Pranav Gulati
Anmol Agrawal
