Automatic Generation of RNS LUTs in MATLAB
A project log for Winter, FPGAs, and Forgotten Arithmetic
RNS on FPGA: Revisiting an Unusual Number System for Modern Signal Processing
bertrand-selvaBertrand Selva 10/16/2025 at 09:020 Comments
This MATLAB/Octave script automatically computes look-up tables (LUTs) for a Residue Number System (RNS) with a given set of moduli. It generates:
Method
The reconstruction follows the classical Chinese Remainder Theorem (CRT):
M  = product of all moduli
Mi = M / mi
Ai = (Mi * inverse(Mi mod mi, mi)) mod M
Tm(r) = (Ai * r) mod M   for r = 0 .. mi-1
Each Tm table stores precomputed modular residues, allowing fast RNS operations on FPGA without any division or modulo logic.
MATLAB/OCTAVE Script
close all;
clear all;
clc;
format long g;
%% RNS LUT generation
%% Moduli list
moduli = [7 11 13 15 17 19 23 29 31];
%% Compute M
M = 1;
for i = 1:length(moduli)
    M = M * moduli(i);
end
disp(M);   % 100280245065
%% Coefficients Ai
Ai = zeros(1, numel(moduli));   % preallocation
for i = 1:numel(moduli)
    m  = moduli(i);
    Mi = M / m;                 % M_i
    t  = mod(Mi, m);            % (M_i mod m)
    [g, x, ~] = gcd(t, m);      % t*x + m*y = g
    if g ~= 1
        error('No modular inverse for m=%d (gcd=%d).', m, g);
    end
    inv_t = mod(x, m);          % inverse of t modulo m
    Ai(i) = mod(inv_t * Mi, M); % A_i = (M_i * inv_t) mod M
end
%% Example LUT Tj (e.g., j=9 -> m = 31)
j  = 9;                         % choose index in 'moduli'
mj = moduli(j);
Tj = zeros(1, mj);              % Tj(r+1) = (Ai(j)*r) mod M
for r = 0 : mj-1
    Tj(r+1) = mod(Ai(j) * r, M);
end
% Display
disp('Ai ='); disp(Ai);
disp(['T' num2str(mj) '(r) for r=0..' num2str(mj-1) ':']);
disp(Tj);
%% Verilog-like table generator
for j = 1:numel(moduli)
    m = moduli(j);
    fprintf('function [36:0] T%d;\n', m);
    fprintf('  input [4:0] r;\n  begin\n    case (r)\n');
    for r = 0:m-1
        fprintf('      5''d%-2d : T%d = 37''d%u;\n', r, m, mod(Ai(j)*r,M));
    end
    fprintf('      default: T%d = 37''d0;\n    endcase\n  end\nendfunction\n\n', m);
end
Notes
Conclusion
This log automates the generation of RNS LUTs and Verilog snippets. Run the script, copy the output, and integrate it directly into your FPGA design without manual editing. Because Typing 300 Constants by Hand Is for Humans...
Results
function [36:0] T7;
  input [4:0] r;
  begin
    case (r)
      5'd0  : T7 = 37'd0;
      5'd1  : T7 = 37'd28651498590;
      5'd2  : T7 = 37'd57302997180;
      5'd3  : T7 = 37'd85954495770;
      5'd4  : T7 = 37'd14325749295;
      5'd5  : T7 = 37'd42977247885;
      5'd6  : T7 = 37'd71628746475;
      default: T7 = 37'd0;
    endcase
  end
endfunction
function [36:0] T11;
  input [4:0] r;
  begin
    case (r)
      5'd0  : T11 = 37'd0;
      5'd1  : T11 = 37'd91163859150;
      5'd2  : T11 = 37'd82047473235;
      5'd3  : T11 = 37'd72931087320;
      5'd4  : T11 = 37'd63814701405;
      5'd5  : T11 = 37'd54698315490;
      5'd6  : T11 = 37'd45581929575;
      5'd7  : T11 = 37'd36465543660;
      5'd8  : T11 = 37'd27349157745;
      5'd9  : T11 = 37'd18232771830;
      5'd10 : T11 = 37'd9116385915;
      default: T11 = 37'd0;
    endcase
  end
endfunction
function [36:0] T13;
  input [4:0] r;
  begin
    case (r)
      5'd0  : T13 = 37'd0;
      5'd1  : T13 = 37'd53997055035;
      5'd2  : T13 = 37'd7713865005;
      5'd3  : T13 = 37'd61710920040;
      5'd4  : T13 = 37'd15427730010;
      5'd5  : T13 = 37'd69424785045;
      5'd6  : T13 = 37'd23141595015;
      5'd7  : T13 = 37'd77138650050;
      5'd8  : T13 = 37'd30855460020;
      5'd9  : T13 = 37'd84852515055;
      5'd10 : T13 = 37'd38569325025;
      5'd11 : T13 = 37'd92566380060;
      5'd12 : T13 = 37'd46283190030;
      default: T13 = 37'd0;
    endcase
  end
endfunction
function [36:0] T15;
  input [4:0] r;
  begin
    case (r)
      5'd0  : T15 = 37'd0;
      5'd1  : T15 = 37'd6685349671;
      5'd2  : T15 = 37'd13370699342;
      5'd3  : T15 = 37'd20056049013;
      5'd4  : T15 = 37'd26741398684;
      5'd5  : T15 = 37'd33426748355;
      5'd6  : T15 = 37'd40112098026;
      5'd7  : T15 = 37'd46797447697;
      5'd8  : T15 = 37'd53482797368;
      5'd9  : T15 = 37'd60168147039;
      5'd10 : T15 = 37'd66853496710;
      5'd11 : T15 = 37'd73538846381;
      5'd12 : T15 = 37'd80224196052;
      5'd13 : T15 = 37'd86909545723;
      5'd14 : T15 = 37'd93594895394;
      default: T15 = 37'd0;
    endcase
  end
endfunction
function [36:0] T17;
  input [4:0] r;
  begin
    case (r)
      5'd0  : T17 = 37'd0;
      5'd1  : T17 = 37'd17696513835;
      5'd2  : T17 = 37'd35393027670;
      5'd3  : T17 = 37'd53089541505;
      5'd4  : T17 = 37'd70786055340;
      5'd5  : T17 = 37'd88482569175;
      5'd6  : T17 = 37'd5898837945;
      5'd7  : T17 = 37'd23595351780;
      5'd8  : T17 = 37'd41291865615;
      5'd9  : T17 = 37'd58988379450;
      5'd10 : T17 = 37'd76684893285;
      5'd11 : T17 = 37'd94381407120;
      5'd12 : T17 = 37'd11797675890;
      5'd13 : T17 = 37'd29494189725;
      5'd14 : T17 = 37'd47190703560;
      5'd15 : T17 = 37'd64887217395;
      5'd16 : T17 = 37'd82583731230;
      default: T17 = 37'd0;
    endcase
  end
endfunction
function [36:0] T19;
  input [4:0] r;
  begin
    case (r)
      5'd0  : T19 = 37'd0;
      5'd1  : T19 = 37'd58056983985;
      5'd2  : T19 = 37'd15833722905;
      5'd3  : T19 = 37'd73890706890;
      5'd4  : T19 = 37'd31667445810;
      5'd5  : T19 = 37'd89724429795;
      5'd6  : T19 = 37'd47501168715;
      5'd7  : T19 = 37'd5277907635;
      5'd8  : T19 = 37'd63334891620;
      5'd9  : T19 = 37'd21111630540;
      5'd10 : T19 = 37'd79168614525;
      5'd11 : T19 = 37'd36945353445;
      5'd12 : T19 = 37'd95002337430;
      5'd13 : T19 = 37'd52779076350;
      5'd14 : T19 = 37'd10555815270;
      5'd15 : T19 = 37'd68612799255;
      5'd16 : T19 = 37'd26389538175;
      5'd17 : T19 = 37'd84446522160;
      5'd18 : T19 = 37'd42223261080;
      default: T19 = 37'd0;
    endcase
  end
endfunction
function [36:0] T23;
  input [4:0] r;
  begin
    case (r)
      5'd0  : T23 = 37'd0;
      5'd1  : T23 = 37'd87200213100;
      5'd2  : T23 = 37'd74120181135;
      5'd3  : T23 = 37'd61040149170;
      5'd4  : T23 = 37'd47960117205;
      5'd5  : T23 = 37'd34880085240;
      5'd6  : T23 = 37'd21800053275;
      5'd7  : T23 = 37'd8720021310;
      5'd8  : T23 = 37'd95920234410;
      5'd9  : T23 = 37'd82840202445;
      5'd10 : T23 = 37'd69760170480;
      5'd11 : T23 = 37'd56680138515;
      5'd12 : T23 = 37'd43600106550;
      5'd13 : T23 = 37'd30520074585;
      5'd14 : T23 = 37'd17440042620;
      5'd15 : T23 = 37'd4360010655;
      5'd16 : T23 = 37'd91560223755;
      5'd17 : T23 = 37'd78480191790;
      5'd18 : T23 = 37'd65400159825;
      5'd19 : T23 = 37'd52320127860;
      5'd20 : T23 = 37'd39240095895;
      5'd21 : T23 = 37'd26160063930;
      5'd22 : T23 = 37'd13080031965;
      default: T23 = 37'd0;
    endcase
  end
endfunction
function [36:0] T29;
  input [4:0] r;
  begin
    case (r)
      5'd0  : T29 = 37'd0;
      5'd1  : T29 = 37'd41495273820;
      5'd2  : T29 = 37'd82990547640;
      5'd3  : T29 = 37'd24205576395;
      5'd4  : T29 = 37'd65700850215;
      5'd5  : T29 = 37'd6915878970;
      5'd6  : T29 = 37'd48411152790;
      5'd7  : T29 = 37'd89906426610;
      5'd8  : T29 = 37'd31121455365;
      5'd9  : T29 = 37'd72616729185;
      5'd10 : T29 = 37'd13831757940;
      5'd11 : T29 = 37'd55327031760;
      5'd12 : T29 = 37'd96822305580;
      5'd13 : T29 = 37'd38037334335;
      5'd14 : T29 = 37'd79532608155;
      5'd15 : T29 = 37'd20747636910;
      5'd16 : T29 = 37'd62242910730;
      5'd17 : T29 = 37'd3457939485;
      5'd18 : T29 = 37'd44953213305;
      5'd19 : T29 = 37'd86448487125;
      5'd20 : T29 = 37'd27663515880;
      5'd21 : T29 = 37'd69158789700;
      5'd22 : T29 = 37'd10373818455;
      5'd23 : T29 = 37'd51869092275;
      5'd24 : T29 = 37'd93364366095;
      5'd25 : T29 = 37'd34579394850;
      5'd26 : T29 = 37'd76074668670;
      5'd27 : T29 = 37'd17289697425;
      5'd28 : T29 = 37'd58784971245;
      default: T29 = 37'd0;
    endcase
  end
endfunction
function [36:0] T31;
  input [4:0] r;
  begin
    case (r)
      5'd0  : T31 = 37'd0;
      5'd1  : T31 = 37'd16174233075;
      5'd2  : T31 = 37'd32348466150;
      5'd3  : T31 = 37'd48522699225;
      5'd4  : T31 = 37'd64696932300;
      5'd5  : T31 = 37'd80871165375;
      5'd6  : T31 = 37'd97045398450;
      5'd7  : T31 = 37'd12939386460;
      5'd8  : T31 = 37'd29113619535;
      5'd9  : T31 = 37'd45287852610;
      5'd10 : T31 = 37'd61462085685;
      5'd11 : T31 = 37'd77636318760;
      5'd12 : T31 = 37'd93810551835;
      5'd13 : T31 = 37'd9704539845;
      5'd14 : T31 = 37'd25878772920;
      5'd15 : T31 = 37'd42053005995;
      5'd16 : T31 = 37'd58227239070;
      5'd17 : T31 = 37'd74401472145;
      5'd18 : T31 = 37'd90575705220;
      5'd19 : T31 = 37'd6469693230;
      5'd20 : T31 = 37'd22643926305;
      5'd21 : T31 = 37'd38818159380;
      5'd22 : T31 = 37'd54992392455;
      5'd23 : T31 = 37'd71166625530;
      5'd24 : T31 = 37'd87340858605;
      5'd25 : T31 = 37'd3234846615;
      5'd26 : T31 = 37'd19409079690;
      5'd27 : T31 = 37'd35583312765;
      5'd28 : T31 = 37'd51757545840;
      5'd29 : T31 = 37'd67931778915;
      5'd30 : T31 = 37'd84106011990;
      default: T31 = 37'd0;
    endcase
  end
endfunction
