Host PC
A project log for ISA-bus slave Z8001 board construction
Building Jacques Pelletier's CPLD-and-SRAM based version of Steve Ciarcia's Trump Card.
keithKeith 09/21/2025 at 16:440 Comments
I have a PC104 computer, but it does not have a case.
I have a nicely cased PC I use for my antique device programming/reading work, but that does get a bit hot and will lock up if I don't leave space between it and the device programmer. There is just enough space for one ISA board inside. I don't know if the board will reduce the airflow enough to cause overheating.
Ideally I would like a case that will show off the Z8000. Perhaps something with a glass side?
