Hardware Connection
As shown in the diagram, connect the red, green, and blue pins of the RGB-LED module to the Arduino pins 1, 2, and 3 on the development board. The RGB-LED used here is a common cathode LED, with the common pin connected to GND. If using a common anode LED, it should be connected to 3.3V.
RGB-LED Module Schematic:https://oshwhub.com/jinleili/rgb-led-module
Code Analysis
#include "BLEDevice.h"
// Choose the RGB LED type
// #define AnodeRGB
#define CathodeRGB
// Choose 3 PWM pins for RGB LED pins refer to the pinmap of using board
#define LED_RED 1
#define LED_GRN 2
#define LED_BLU 3
#define UART_SERVICE_UUID "6E400001-B5A3-F393-E0A9-E50E24DCCA9E"
#define CHARACTERISTIC_UUID_RX "6E400002-B5A3-F393-E0A9-E50E24DCCA9E"
#define CHARACTERISTIC_UUID_TX "6E400003-B5A3-F393-E0A9-E50E24DCCA9E"
#define STRING_BUF_SIZE 100
BLEService UartService(UART_SERVICE_UUID);
BLECharacteristic Rx(CHARACTERISTIC_UUID_RX);
BLECharacteristic Tx(CHARACTERISTIC_UUID_TX);
BLEAdvertData advdata;
BLEAdvertData scndata;
bool notify = false;
void readCB(BLECharacteristic* chr, uint8_t connID)
printf("Characteristic %s read by connection %d \n", chr->getUUID().str(), connID);
void writeCB(BLECharacteristic* chr, uint8_t connID)
printf("Characteristic %s write by connection %d :\n", chr->getUUID().str(), connID);
uint16_t datalen = chr->getDataLen();
if (datalen > 0) {
if (chr->readData8() == '!') {
uint8_t command[datalen];
chr->getData(command, datalen);
if (command[1] == 'C') {
// print hex
printf("Color command R = %x G = %x B = %x \n", command[2], command[3], command[4]);
// print decimal
// printf("Color command R = %d G = %d B = %d \n", command[2], command[3], command[4]);
#if defined(CathodeRGB)
analogWrite(LED_RED, command[2]);
analogWrite(LED_GRN, command[3]);
analogWrite(LED_BLU, command[4]);
#elif defined(AnodeRGB)
analogWrite(LED_RED, (255 - command[2]));
analogWrite(LED_GRN, (255 - command[3]));
analogWrite(LED_BLU, (255 - command[4]));
#else
printf("Error, please choose the RGB LED type \n");
#endif
} else {
Serial.print("Received string: ");
Serial.print(chr->readString());
Serial.println();
void notifCB(BLECharacteristic* chr, uint8_t connID, uint16_t cccd)
if (cccd & GATT_CLIENT_CHAR_CONFIG_NOTIFY) {
printf("Notifications enabled on Characteristic %s for connection %d \n", chr->getUUID().str(), connID);
notify = true;
} else {
printf("Notifications disabled on Characteristic %s for connection %d \n", chr->getUUID().str(), connID);
notify = false;
void setup()
Serial.begin(115200);
pinMode(LED_RED, OUTPUT);
pinMode(LED_GRN, OUTPUT);
pinMode(LED_BLU, OUTPUT);
analogWrite(LED_RED, 255);
analogWrite(LED_GRN, 255);
analogWrite(LED_BLU, 255);
advdata.addFlags(GAP_ADTYPE_FLAGS_LIMITED | GAP_ADTYPE_FLAGS_BREDR_NOT_SUPPORTED);
advdata.addCompleteName("AMEBA_BLE_DEV");
scndata.addCompleteServices(BLEUUID(UART_SERVICE_UUID));
Rx.setWriteProperty(true);
Rx.setWritePermissions(GATT_PERM_WRITE);
Rx.setWriteCallback(writeCB);
Rx.setBufferLen(STRING_BUF_SIZE);
Tx.setReadProperty(true);
Tx.setReadPermissions(GATT_PERM_READ);
Tx.setReadCallback(readCB);
Tx.setNotifyProperty(true);
Tx.setCCCDCallback(notifCB);
Tx.setBufferLen(STRING_BUF_SIZE);
UartService.addCharacteristic(Rx);
UartService.addCharacteristic(Tx);
BLE.init();
BLE.configAdvert()->setAdvData(advdata);
BLE.configAdvert()->setScanRspData(scndata);
BLE.configServer(1);
BLE.addService(UartService);
BLE.beginPeripheral();
void loop()
if (Serial.available()) {
Tx.writeString(Serial.readString());
if (BLE.connected(0) && notify) {
Tx.notify(0);
delay(100);
To know more: https://www.amebaiot.com/en/amebapro2-arduino-ble-pwm/
Compilation and Upload
- Open the example program PWM_over_BLEUart.
- Hold the BOOT (download) button while pressing the EN (reset) button to enter download mode.
- Select the appropriate target serial port and click the Download button. Wait for the success message.
- Press the EN button again to reset and start the program.
Testing Process
- Install and open the Adafruit Bluefruit LE Connect app on your phone.
- Turn on Bluetooth and scan for nearby Bluetooth devices, then connect to AMEBA_BLE_DEV.
- Select Controller → Color Picker, then choose a color from the color wheel and click SELECT to display the target color.
Conclusion
This article introduces the Ai-Thinker BW21-CBV-Kit development kit to implement a Bluetooth RGB light. It covers the project introduction, code analysis, operation process, and effect display, providing a reference for development in wireless control and other IoT applications.
Ai-Thinker
