The USB QuadPort VE.Direct is a compact USB-to-4-port UART interface designed for seamless integration within the Victron Energy ecosystem.
It enables simultaneous connection of multiple VE.Direct devices—such as solar charge controllers, battery monitors, and inverters—to a single USB port.
This makes it especially valuable in solar panel installations, where monitoring and managing energy production, storage, and consumption are critical.
By consolidating data streams from different components, the QuadPort VE.Direct simplifies system diagnostics, enhances real-time monitoring, and ensures smooth communication across the entire Victron setup.
Powered by the reliable FTDI FT4232H chipset, it supports data rates up to 12 Mb/s per port.
The device connects via USB-C and is compatible with Venus OS, Raspberry Pi, Windows, Linux, Android, and macOS.
Each port operates at 3.3V to 5V and includes power, TX, and RX LEDs with an internal switch to disable them. Housed in a durable plastic enclosure.
it’s plug-and-play on Venus OS with no drivers needed. Ideal for expanding VE.Direct connectivity in solar, off-grid, or industrial setups.
Features
- Original FTDI FT4232H-56Q
- Up to 12Mb/s each port
- Plastic case 97 x 41 x 20 mm
- 4 isolated port VE.Direct
- Compatible with original Victron cables
- Each ports can work independently at 3.3V up to 5V
- Power, TX and RX LEDs indicators
- Internal switch for disable/enable the LEDs
- USB type-C connector
- Compatible with: Linux, Windows, Android and Mac OS
An internal micro switch currently manages LED control. Future revisions will feature an external switch for enhanced accessibility.
The enclosure is based on the BMW 50032 plastic case, custom-milled to accommodate the PCB connectors and LED layout. The mechanical design was developed using Autodesk Fusion.
Saimon
Lithium ION
Vitaly Kornilov
