#### 1. **Multilingual Support**
- **Languages Supported**: Dutch (NL), French (FR), English (EN), German (DE), Spanish (ES), and Italian (IT).
- **Text Localization**: The script uses a `TEXTS` dictionary to store UI labels and messages for each language, allowing seamless switching between languages via a dropdown menu.
- **Ingredient and Recipe Translation**: Ingredients and recipe names are translated based on XML files (`BakeryTool1.xml` for ingredients, `BakeryTool2.xml` for recipes, and `BakeryTool3.xml` for conversion factors).
#### 2. **Ingredient Management**
- **Dynamic Ingredient Loading**: Ingredients are loaded from `BakeryTool1.xml`, which defines ingredient names and their translations across supported languages.
- **Extra Ingredients**: The GUI includes fields for three additional custom ingredients (labeled as "extra 1", "extra 2", "extra 3" by default, with language-specific names like "supplémentaire" in French).
- **Normalization**: Ingredient names are normalized (e.g., removing units like "(g)" or "(ml)") for consistent processing across languages.
#### 3. **Recipe Management**
- **Recipe Loading**: Recipes are loaded from `BakeryTool2.xml`, which contains recipe names, their translations, and ingredient quantities.
- **Recipe Selection**: Users can select from a list of predefined recipes in a pop-up window, which populates the ingredient fields with corresponding quantities.
- **Custom Input**: Users can manually enter or modify ingredient quantities, supporting both predefined and custom ingredients.
#### 4. **Weight Calculations**
- **Total Weight Calculation**: The script calculates the total weight of ingredients entered in the GUI, applying conversion factors from `BakeryTool3.xml` (e.g., to account for different densities or measurement units).
- **Rescaling**: Users can rescale ingredient quantities to achieve a desired total weight using multiplication, division, or per-piece calculations (e.g., specifying the number of pieces and weight per piece).
- **Error Handling**: The script prevents invalid operations, such as:
- Combining per-piece calculations with multiplication/division.
- Using both multiplication and division simultaneously.
- Rescaling when the current total weight is zero or when invalid inputs are provided.
#### 5. **Output Options**
- **PDF Generation**: Users can generate a PDF file listing the ingredient quantities and total weight, with a customizable file name.
- **Printing**: users can print the recipe directly to a printer. A temporary PDF is created and sent to the printer queue.
- **Email Sharing**: Users can send the recipe details (ingredients and total weight) via a `mailto` link, which opens the default email client with pre-filled subject and body.
#### 6. **Dependency Management**
- **Required Libraries**: The script checks for `tkinter` and `reportlab`.
#### 7. **User Interface Features**
- **GUI Layout**: The interface includes:
- A language selection dropdown.
- Input fields for ingredients and extra ingredients.
- A recipe selection button and listbox.
- Buttons for calculating total weight, resetting values, generating PDFs, printing, emailing, and closing the application.
- A display for the current total weight and a field for entering a new total weight for rescaling.
- **Pop-up Windows**:
- **Recipe Selection Window**: Displays a list of recipes for selection.
- **Multiplication Window**: Allows users to input multiplication/division factors or per-piece calculations to rescale quantities.
- **Auto-Closing Message Boxes**: Informational and error messages close automatically after a set duration (e.g., 3 seconds).
- **UI State Management**: Input fields and buttons are disabled during recipe selection or rescaling to prevent conflicts.
#### 8. **Error Handling and Robustness**
- **XML Parsing**: The script handles XML parsing errors (e.g., file not found, permission issues,...
wils Nico
Edgaras Art
TAIBHSE DESIGNS
Grant Pitel
