Introduction
The VS1053b is an audio codec chip that supports a wide variety of formats, including Ogg Vorbis, MP3, AAC, WMA, FLAC, and MIDI. For applications in electronic musical instruments, its Real-Time MIDI mode is particularly useful. Simply by sending MIDI commands to the chip via UART, you can play the sounds of various musical instruments.
Real-Time MIDI mode
To use Real-Time MIDI mode, you need to ensure that GPIO0 is low and GPIO1 is high when the chip is powered on; after that, it's ready for use.
No additional commands or control from an external MCU are necessary. It's very simple.
GPIO0 is configured as a pull-down, and GPIO1 is configured as a pull-up.
All that's left to do is send MIDI commands to the VS1053b, and the sound will be played.
MIDI IN
The MIDI signal is processed by a standard MIDI input circuit, where the signal from the MIDI connector is isolated using a photo-coupler and then connected to the UART RX pin of the VS1053b chip.
PCB
Thanks to the PCBWay, I was able to produce high-quality circuit boards quickly this time.
The circuit board arrived in Japan about a week after I placed the order.
The delivery time was short, and the matte black solder resist we specified turned out beautifully.
I was satisfied with the quality.
After I received the PCB, I manually soldered the components onto the PCB.
DEMO VIDEO
Please watch this demo video which shows various instrument sounds from the VS1053b chip being played via MIDI.
Hiro Akihabara
Michael Wessel
samuel.cusumano
