Evezor Robotics and Automation Platform
A Networked set Robotic Arms, Motion platforms, sensors and more.
Easily programmed with a drag and drop interface.
A Networked set Robotic Arms, Motion platforms, sensors and more!
So stay tuned!! Please give a like or a follow for updates.
This project has gotten massive but here's a small overview:
Introducing our newest robotic arm: Tobor
Tobor is a fully featured robotic system that can fit on your desktop and is capable of helping you automate your workflow. Tobor (robot spelled backwards), was built to be the most versatile open-source robotics system, which can be customized endlessly to meet your automation needs. Easily combine robotic arms, motion platforms, sensors, actuators, and more to create your unique machine.
See more on our Crowd Supply Page
We're working hard to get all the source files in order. The best way to get them the soonest would be to follow our campaign
Use Tobor to Draw
Use Tobor to Assemble Circuit Boards
Edge Boards
Edge boards are a suite of discrete open source electronics boards networked through an open protocol developed by us and programmed using an easy to use drag and drop interface, also created by us. Network mediums currently are focused primarily on CAN bus, MQTT, and some APIs hosted by Evezor, covering the base cases of ease of use, low latency and communications over the internet.
Floe IDE
FLOE IDE is a drag and drop flow based programming language used to network robots over whatever but they are connected to. For quite a while now in the software world we've had tools like docker and kubernetes. Now it's time for the hardware world to have the same thing.
You can find a demo here: https://floe.evezor.com
Short Demo of Boards and IDE
One of my favorite videos
Santa wants to get some of our arms under some Christmas trees
And love for Hackaday
https://i.imgur.com/iYR05tR.mp4
I've got a ton coming so follow here and subscribe to us on Crowd Supply
https://www.crowdsupply.com/evezor-inc/tobor-robotics-and-automation-platform
schematic.pdf
tobor's first iteration of controller board
Adobe Portable Document Format - 1.08 MB - 10/14/2024 at 03:19
Preview
View all 61 project logs
Vittorio Lumare wrote 11/13/2025 at 18:44 • point
Hi, how much payload can it hold? I am building a robotic hand and I am selecting a low cost arm for it.
malvasio wrote 08/31/2017 at 07:38 • point
hi
is your scara use a rpicam and opencv ?
rpi2/3 ?
pick &place is nice but can it solder electronic too ?
i' m too much handicapped to use normal tools but i have lot of projects
so is your scara able to fully replicate itself for example ?
i have an arm project (mounted on a chassis with wheels to gain precision + reach) i absolutely need
Oskar Weigl wrote 06/02/2017 at 03:16 • point
Interested in a collaboration to mix in high power servo drives?
https://hackaday.io/project/11583-odrive-high-performance-motor-control
GrayPillow wrote 06/02/2017 at 03:25 • point
I think it's a goode Idea!
anfroholic wrote 06/24/2017 at 08:07 • point
Yes definitely!  For the time being we're basing most of our hardware around the smoothieboard which has stepper drives standard,  we have our eyes on moving in that direction for our next rev.  Thanks!
Oskar Weigl wrote 06/24/2017 at 17:08 • point
Have a look at the Juicyboard. It is based on the Smoothieboard, and supports many kinds of drive systems. ODrive will be included too.
https://www.crowdsupply.com/plugg-ee-labs/juicyboard#other-modules-in-the-pipeline
anfroholic wrote 06/25/2017 at 10:35 • point
It's not letting me reply to your comment below so I will write it here.  "will be" makes it unfit for use at the moment.  I cannot use something unproven just yet.  Thanks for the heads up, that looks like a cool board and I will be keen on following its and your developement.
GrayPillow wrote 05/31/2017 at 03:41 • point
Nice project, I have a plan to build a scara robot arm based on yours , and apply my control system https://hackaday.io/project/20980-ananasstepper-20
anfroholic wrote 06/24/2017 at 07:57 • point
Cool! Nice drives!
wydmynd wrote 05/30/2017 at 07:07 • point
Hi! amazing project! As someone who was part of starting a hackerspace  I admire your commitment to all aspects of the project, implementing various applications, and general forward thinking. As someone who is interested in building robot arms, I am interested in the motor control aspects of the robot. I plan to use magnetic encoders. I noticed them in all the videos but they are barely mentioned elsewhere. Most 3D printers use stepper motors without encoder, and digging through the GitHub repo I could not find how these come into play. I see videos of you teaching the robot (impossible without encoders) - I assume this is all done with Processing code that runs on the Raspi? in conclusion I would really suggest adding a system diagram - what connects to what and how. the only place I found something similar was on the Kickstarter page for your project. Hopefully I can build on some of your work and share the results.
anfroholic wrote 06/24/2017 at 08:01 • point
Thank you. At the moment the arm is driven primarily open loop. The encoders were only used directly in the collaboration demo.  I have taken off the encoders for the moment due to people telling me they're too ugly...  they will be coming back on board in the next rev along with full support as we have decided to opt with smoothieboard for the time being.
kaoda wrote 05/04/2017 at 06:57 • point
Perfect work!
just one question - what if steppers used are geared ones? Like 5,18:1, NEMA 17?
Are this will be enough for same movement clearance and power ratio?
anfroholic wrote 05/08/2017 at 20:43 • point
Thank you! You run into speed vs. power compromises. A geared NEMA 17 would be slower than a straight NEMA 23.  Also depending on how you have things geared you may end up with undesirable backlash with a gearbox.
kaoda wrote 05/09/2017 at 12:14 • point
You are totally right my friend! Great job!
Morning.Star wrote 03/25/2017 at 10:18 • point
Lol I was going to ask what the banana was for but I made it down here anyway :-)
Really nice piece of heavy metal you have there, beautiful build. You must have a sweet workshop to be able to machine those parts...
anfroholic wrote 03/25/2017 at 23:54 • point
I am very fortunate, yes.  Thank you for the kind comments.
