This weather station board features a barometric pressure sensor, an ambient light sensor and a temperature and humidity sensor.
Source files can be found here: https://github.com/evezor/v0_weather_station_board
This board uses the Evezor Stamp STMF405 MCU
Hey -- neat to see new activity on an ambitious project!
If you want to dress for photos, you can clean up FR4 perf board edges right quick on a coarse sharpening stone. IME water captures the mean glass dust and lead falls out of the water.
https://www.instructables.com/Clean-Cut-FR4-Perfboard-ProtoboardPrototype-PCB/#step4
Awesome! Thanks for the tip. Although I don't think I've made a horrible little bodge board since that thing. I may be able to use that tip on other places tho. I don't like the edges sometimes with v-cuts or mousebites. Thanks again!
You're welcome :}. Unplated or lead-free edges you could do trivially under running water (assuming wastewater treatment does something sensible with glass & resin dust). Prolly a single stroke on a diamond stone for a v-cut edge.
