An edge board with a DRV8825 stepper motor driver, limit switch connections and encoder inputs
source files can be found here: https://github.com/evezor/v0_stepper_driver_drv8825
This board uses the Evezor Stamp STMF405 MCU
A project log for Evezor Robotics and Automation Platform
A Networked set Robotic Arms, Motion platforms, sensors and more. Easily programmed with a drag and drop interface.
