Day 25: evezor_arm_v1_mainboard_v1
A project log for Evezor Robotics and Automation Platform
A Networked set Robotic Arms, Motion platforms, sensors and more. Easily programmed with a drag and drop interface.
anfroholicanfroholic • 10/08/2023 at 01:53•0 Comments
This board is based on the RAMPS1.4 Board https://reprap.org/wiki/RAMPS_1.4
The motor connectors have been changed to Molex KK connectors and the extra pins are broken out in the Gadgeteer Standard pinout
Source files can be found here: https://github.com/evezor/evezor_arm_v1_mainboard_V1
