Today we plasma cut the letter E out of sheet metal.
The toolehead is a standard handheld plasma cutter. I used a small solenoid for the trigger mechanism.
The material is 12ga mild steel.
The toolpath was created in inkscape
See our blog post on this job at http://evezor.com/plasma-cutting/
anfroholic
