Just added a power point/google slides style 2D sheets editor that lets you insert PMI views and put other information on to a page. It supports a bunch of different sheet sizes and outputs PDF documents.
Fun fact. When you save a model a PDF gets generated and stuffed in to the 3MF file. 3MF files are basically a zip file so extra stuff can go in there like your build instructions or inspection documents.
mmiscool
