Built-In OLED Oscilloscope & Spectrum Analyzer
A project log for 64-Knob Virtual-Analog Synth on Pico 2
A 64-knob virtual-analog synthesizer on Raspberry Pi Pico 2 — fully tactile, no menus, real-time control.
hiroyuki-oyamaHiroyuki OYAMA 01/06/2026 at 11:580 Comments
I just added two new visualization tools to Darśana’s OLED UI: a tiny oscilloscope and a spectrum analyzer.
They’re mostly “cosmetic” features, but during development I kept having to power up and connect an external scope (and then re-route cables, re-trigger, etc.). It was annoying enough that I decided: why not put the scope on the synth itself? Now I can sanity-check waveform shape, clipping, and spectral balance instantly — no bench setup required.
And yes… it’s kind of cute.
Bonus: “nonlinear ramp” saw (Model D-ish)
One fun discovery while staring at waveforms: many real analog synth waveforms aren’t perfectly straight ramps. Because of things like capacitor charge/discharge behavior and other non-idealities, the “saw” slope can have a slight curve.
So I implemented a nonlinear ramp saw inspired by the Moog Minimoog Model D waveform. Visually, it definitely looks more “analog” than a perfectly linear ramp — but honestly, I’m not sure I can hear the difference in isolation.
Can you? If I upload a short clip, would you be able to pick it reliably?
