A New Direction: A Corrected Forward-Euler Ladder, 4× Oversampling, and Built-In FX
A project log for 64-Knob Virtual-Analog Synth on Pico 2
A 64-knob virtual-analog synthesizer on Raspberry Pi Pico 2 — fully tactile, no menus, real-time control.
hiroyuki-oyamaHiroyuki OYAMA 05/08/2026 at 07:340 Comments
I have made a major change in the DSP direction of Darśana.
In my measurement bench, I found a new way to compensate for the discretization errors of a forward-Euler ladder filter; especially cutoff tuning and resonance behavior near the high-frequency range.
With this correction, the forward-Euler ladder now performs at a level comparable to, and in some cases better than, my previous TPT/bilinear ZDF ladder implementation in my measurement bench.
The important result is simple:
I can now get a more analog-like sound from a much lighter ladder structure.
This changes the design trade-off significantly. Instead of spending most of the CPU budget on a heavy zero-delay feedback ladder, I can use a corrected forward-Euler ladder core, run the nonlinear filter section at 4× oversampling; 192 kHz internally; and still have room for more musical features.
Core 0 is fully dedicated to the main synth engine:
At the same time, I have started using Core 1 for built-in stereo effects. The current firmware now includes chorus and delay running alongside the main synth engine.
The result is a richer, wider, and more analog-like sound than before, while still running on the Raspberry Pi Pico 2 / RP2350.
Please listen to how far this little microcontroller can be pushed.
