new version had moved away from GTK / MSYS
A project log for Remote Linux Manager
The Remote Linux Manager is a robust, multi-threaded GUI application designed for centralising the management, monitoring, maintenance
diddydiddy 10/23/2025 at 22:210 Comments
The latest version has moved away from GTK front end for easier setup and running under Linux and Windows.
Looks a bit more dated but I had to trade off how the tool looks for stability and ease of setup under windows and Linux.
The only requirement now is Python and a lot easier to run up under windows.
On first run up any additional addons will be installed so you may be asked during the first run up.
On first run up the pyhton virtual runtime environment and the secret key is created along with the SQL lite database.
other run up of the tool will start quicker due to everything being in place.
