Introduction
In this tutorial, we’ll build a home-automation controller using a Raspberry Pi Zero W, two MOSFET switches, and a minimal Flask web console.
By the end, you’ll be able to toggle devices ON/OFF from your phone or laptop over Wi-Fi. We’ll keep the circuit clean, the power safe, and the code simple so you can customize it later.
Components You’ll Need
Why Raspberry Pi Zero W
Video Tutorial
Want a fully functional smart home system without the high cost? This is the ultimate DIY Home Automation project using the tiny, ultra-cheap Raspberry Pi Zero W!
Circuit
Circuit – Full Explanation
The circuit is simple and reliable. We use two low-side N-MOSFET switches controlled by the Pi’s GPIO pins.
Behavior: When the Pi drives the gate HIGH, the MOSFET turns ON and completes the path to ground → the device receives power from 12 V and turns ON.
When the gate goes LOW, the device turns OFF.
Pin Map (BCM → Physical Header Pin)
We use BCM numbering in the code. The physical positions help if you wire from a loose Pi.
Power
We have two rails:
Power the Pi in one of two ways:
  1. A good 5 V USB supply into the Pi, or
  2. A switching regulator like TSR 1-2450 stepping 12 V down to 5 V.
Avoid a linear 7805 from 12 V; it overheats at Pi currents.
If you might use USB and the 5 V regulator at the same time, isolate them—add a series Schottky diode from the regulator to the Pi 5 V rail (or use an ideal-diode/power-mux IC) to prevent back-feeding.
Voltage Regulator
The TSR 1-2450 is a drop-in switching replacement for 7805. It delivers a cool, efficient 5 V up to 1 A from 9–12 V input.
Place a 10–22 µF capacitor near VIN and a 22–47 µF capacitor near the 5 V output for stability during Wi-Fi spikes.
If you plan heavy 5 V USB devices, consider a 1.5–2 A regulator.
GPIO Voltage
Pi GPIO is 3.3 V logic. Pick MOSFETs that turn fully ON at Vgs ≈ 3.3 V with low Rds(on) (e.g., AO3400A, IRLZ44N, FQP30N06L).
Always include the gate series resistor and the 100 kΩ pulldown for clean, predictable switching.
Advantage of Using a PCB
A PCB gives you:
Prototype on a breadboard first, then move the same netlist to PCB for reliability.
Setting up the Pi
Initial Testing of GPIO Pins (Simple Code)
Before the web UI, test that GPIO 23 and 24 switch correctly
File: simple_on_off_test.py
# simple_on_off_test.py
import time
import RPi.GPIO as GPIO
GPIO.setmode(GPIO.BCM)
GPIO.setup(23, GPIO.OUT, initial=GPIO.LOW)
GPIO.setup(24, GPIO.OUT, initial=GPIO.LOW)
# Turn ON GPIO 23 for 2s
GPIO.output(23, GPIO.HIGH)
time.sleep(2)
GPIO.output(23, GPIO.LOW)
# Turn ON GPIO 24 for 2s
GPIO.output(24, GPIO.HIGH)
time.sleep(2)
GPIO.output(24, GPIO.LOW)
GPIO.cleanup()
Run with:
sudo python3 simple_on_off_test.py
Install Libraries (Option A — apt for Pi Zero W)
On Bookworm, use apt for a smooth experience on the Zero W:
sudo apt update
sudo apt install -y python3-rpi.gpio python3-flask
Home Automation Web Console (Flask)
Now we’ll create a tiny web console to toggle the two channels from any browser on your LAN.
File: home_automation.py
#!/usr/bin/env python3
# home_automation_v2.py — 6 devices (3 rows × 2 cols)
import atexit
from datetime import datetime
from flask import Flask, render_template_string, jsonify, request, abort
TITLE = "RootSaid • Home Automation"
BRAND = "RootSaid"
SITE_URL = "https://rootsaid.com"
# Edit names/pins to match your PCB (BCM numbering)
DEVICES = [
    {"pin": 23, "name": "Light 1 — GPIO 23"},
    {"pin": 24, "name": "Fan 1 — GPIO 24"},
    {"pin": 25, "name": "Device 3 — GPIO 25"},
    {"pin": 26, "name": "Device 4 — GPIO 26"},
    {"pin": 17, "name": "Device 5 — GPIO 17"},
    {"pin": 27, "name": "Device 6 — GPIO 27"},
# --- GPIO setup ---
GPIO.setwarnings(False)
for d in DEVICES:
    GPIO.setup(d["pin"], GPIO.OUT, initial=GPIO.LOW)
state = {d["pin"]: False for d in DEVICES}
def set_pin(pin: int, on: bool):
    GPIO.output(pin, GPIO.HIGH if on else GPIO.LOW)
    state[pin] = on
@atexit.register
def _cleanup():
    for d in DEVICES:
        GPIO.output(d["pin"], GPIO.LOW)
    GPIO.cleanup()
app = Flask(__name__)
INDEX_HTML = '''
<!doctype html>
<html lang="en">
<head>
  <meta charset="utf-8">
  <meta name="viewport" content="width=device-width,initial-scale=1">
  <title>{{ title }}</title>
  <style>
    :root{--bg:#0e0f12;--card:#181b22;--muted:#9aa1ac;--text:#e6e9ef;
          --ok:#00d18f;--bad:#e74c3c;--accent:#007aff;}
    *{box-sizing:border-box} html,body{margin:0;height:100%}
    body{font-family:system-ui,-apple-system,Segoe UI,Roboto,Helvetica,Arial;color:var(--text);background:var(--bg)}
    .wrap{max-width:980px;margin:0 auto;padding:24px}
    .top{display:flex;justify-content:space-between;align-items:center;gap:12px}
    h1{margin:0;font-size:clamp(20px,3vw,28px)}
    .muted{color:var(--muted)} a{color:var(--accent);text-decoration:none}
    /* Fixed 2 columns -> 3 rows (with 6 items) */
    .grid{display:grid;grid-template-columns:repeat(2,minmax(280px,1fr));gap:16px;margin-top:16px}
    @media (max-width:640px){ .grid{grid-template-columns:1fr} }
    .card{background:var(--card);border:1px solid #2a2d36;border-radius:14px;padding:16px}
    .card h3{margin:0 0 6px}
    .status{margin-top:2px}.dot{display:inline-block;width:10px;height:10px;border-radius:50%;margin-right:8px}
    .on{background:var(--ok)} .off{background:var(--bad)}
    .row{display:flex;gap:10px;margin-top:12px}
    .btn{flex:1;border:0;border-radius:10px;padding:12px 14px;color:#fff;font-weight:600;cursor:pointer}
    .onb{background:#0ab685} .offb{background:#c8453b}
    footer{margin-top:18px;font-size:13px;color:var(--muted);display:flex;justify-content:space-between;gap:8px;flex-wrap:wrap}
  </style>
</head>
<body>
  <div class="wrap">
    <div class="top">
      <div>
        <h1>{{ title }}</h1>
        <div class="muted">Control panel for your Raspberry Pi Zero W • Powered by {{ brand }}</div>
      </div>
      <div><a href="{{ site_url }}" target="_blank" rel="noopener">Visit {{ brand }}</a></div>
    </div>
    <div id="cards" class="grid">
      {% for d in devices %}
      <div class="card" data-pin="{{ d.pin }}">
        <h3>{{ d.name }}</h3>
        <div class="status">
          <span class="dot {{ 'on' if state[d.pin] else 'off' }}"></span>
          <span class="label">{{ 'ON' if state[d.pin] else 'OFF' }}</span> • GPIO {{ d.pin }}
        </div>
        <div class="row">
          <button class="btn onb"  onclick="send({{ d.pin }}, 'on')">Turn ON</button>
          <button class="btn offb" onclick="send({{ d.pin }}, 'off')">Turn OFF</button>
        </div>
      </div>
      {% endfor %}
    </div>
    <footer>
      <div>© {{ year }} {{ brand }} • <a href="{{ site_url }}" target="_blank">rootsaid.com</a></div>
      <div>Device: {{ request.host }}</div>
    </footer>
  </div>
<script>
async function send(pin, mode){
  try{
    const r = await fetch('/api/toggle', {
      method:'POST', headers:{'Content-Type':'application/json'},
      body: JSON.stringify({pin:pin, mode:mode})
    if(!r.ok) throw new Error('HTTP '+r.status);
    await refresh();
  }catch(e){ alert('Failed: '+e.message); }
async function refresh(){
  const r = await fetch('/api/state'); if(!r.ok) return;
  const data = await r.json();
  document.querySelectorAll('.card').forEach(card=>{
    const pin = Number(card.dataset.pin);
    const on = !!data.state[pin];
    const dot = card.querySelector('.dot');
    const label = card.querySelector('.label');
    dot.classList.toggle('on', on);
    dot.classList.toggle('off', !on);
    label.textContent = on ? 'ON' : 'OFF';
setInterval(refresh, 2000);
</script>
</body>
</html>
@app.get("/")
def index():
    return render_template_string(
        INDEX_HTML, title=TITLE, brand=BRAND, site_url=SITE_URL,
        devices=DEVICES, state=state, year=datetime.now().year, request=request
@app.get("/api/state")
def api_state():
    return jsonify({"ok": True, "state": state})
@app.post("/api/toggle")
def api_toggle():
    data = request.get_json(silent=True) or {}
    pin = data.get("pin"); mode = data.get("mode")
    pins = [d["pin"] for d in DEVICES]
    if pin not in pins or mode not in ("on","off"):
        return abort(400)
    set_pin(pin, on=(mode=="on"))
    return jsonify({"ok": True, "pin": pin, "on": state[pin]})
if __name__ == "__main__":
    app.run(host="0.0.0.0", port=8000, debug=False)
Run it:
sudo python3 home_automation.py
Then open:
http://<your-pi-ip>:8000
How It Works?
Troubleshooting
Safety Notes
