Software Architecture Deep Dive: Events, Tasks & Pipelines
A project log for Stray
ESP32-based digital walkie-talkie (VoIP) for local Wi-Fi networks.
alexAlex • 10/25/2025 at 10:27•0 Comments
After covering the hardware in the last post, let's dive into what makes it tick: the software architecture.
When I refactored this project from its old Arduino-based monolith, my main goal was to create a clean, flexible, and scalable system. I built the entire architecture around FreeRTOS and a layered, event-driven model.
Here’s a breakdown of the key layers:
1. The Foundation: BSP & HAL
This is the lowest layer, separating the "application logic" from the physical hardware.
BSP (Board Support Package): This is the core of the hardware abstraction. It’s defined by a single struct (bsp_t) containing function pointers for all hardware operations. A global pointer (g_bsp) is used by all other modules to access hardware.
HAL (Hardware Abstraction Layer): These are the drivers using the BSP. They manage the specific peripherals (hal_display, hal_audio, hal_encoder).
2. The Heart: The Main Event Queue
This is the true center of the entire system. Instead of tasks calling each other directly, most modules send messages to a single, central queue: main_queue_event.
An app_event_t structure is as follows:
typedef struct {
    app_event_source_t source;
    uint8_t CmdCode;
    app_event_payload_t payload;
} app_event_t;
can come from various sources:
typedef enum {
    EVENT_SOURCE_INPUT,
    EVENT_SOURCE_WIFI,
    EVENT_SOURCE_CHANNEL,
    EVENT_SOURCE_GUI,
    EVENT_SOURCE_SNTP
    // ... you can easily add any
} app_event_source_t;
 as CmdCode could be used custom enums for specific source
typedef enum { INPUT_ENCODER_TURN, INPUT_KEY_PRESS } input_event_type_t;
typedef enum { WIFI_EVENT_CONNECTED, WIFI_EVENT_DISCONNECTED, WIFI_EVENT_STA_READY} wifi_event_type_t;
typedef enum { SNTP_EVENT_TIME_SYNCED } sntp_event_type_t;
typedef enum { CHANNEL_EVENT_PEER_SPEAKING, CHANNEL_EVENT_PEER_SPEAKING_END , CHANNEL_EVENT_PEER_LIST_CHANGED} channel_event_type_t;
typedef enum { GUI_EVENT_CONNECT_TO_SERVER, GUI_EVENT_PEER_SELECTED } gui_event_type_t;
payload also easily enchanced
typedef union {
    struct {
        uint8_t key_code;
        int16_t press_type;
        uint32_t timestamp_ms;
    } input;
    struct {
        bool is_connected;
    } wifi;
    struct{
        uint64_t peer_speaking;
    }channel;
    struct{
        uint16_t selected_peer;
        peer_info_t peer_info;
    }gui;
} app_event_payload_t;
This means we have one primary handler in main() that receives all these events and decides what to do next.
3. Synchronization: The System Event Group
If the main_queue is for sending messages, the system_event_group is for signaling states. This is crucial for synchronizing tasks. For example, the lan_task waits for the WIFI_CONNECTED_BIT (set by hal_net) before it starts running.
4. The "Worker" Modules
These are the other key modules that run as separate tasks and interact with the event system:
5. The Audio Pipeline
This is the most complex part of the project. It's a two-way process (Record/Transmit and Receive/Play) managed by FreeRTOS tasks, queues, and a shared memory pool.
The key feature here is the shared_buffer_pool. Using this and two independent queues (mic_to_net_queue and net_to_speaker_queue) allows the I2S, network, and audio tasks to pass data around efficiently without extra memory copies.
Having any further questions, feel free to reach out and ask
