After much introspection, it looks like I am going to make some changes:
- 3D Printed drive and idler sprockets at 17 teeth instead of 11
- 3D Printed road wheels (yes, printed), but also at 17 teeth, that will raise the chassis of the tank higher off the ground.
- Move forward with making the tank based on a metal frame instead of a wooden one. 2 of the 2x4s will be recycled as longitudinal support members
- Fiberglass surfaces so that the batteries can be mounted inside the frame cavity
Plastic wheels and sprockets will save the track a lot more, and based on initial estimates will suffice for prototyping. They may not handle heavy duty operations, but it's pretty easy to cast aluminum replacements afterwards. I do intend to print in PLA at 100% in-fill.
Here's an image of the sprocket/idler:
