DeskNode
A modular, desk-mounted PC command hub powered by rEFInd and Raspberry Pi Pico.
Public Chat
0 followers
DeskNode // System Control Interface v0.4
DeskNode is a modular, desk-integrated system interface designed to merge industrial hardware design with digital control precision.
It’s not just a front panel — it’s the command center of your machine.
Machined to fit flush into a corner cutout of the desk, DeskNode centralizes all essential I/O and control features into a clean, tactile layout:
Power and Reset switches, connected directly to the motherboard via extension lines.
Power and HDD status LEDs — hardware-level indicators with that old-school diagnostic vibe.
Four USB 3.0 ports, front-mounted through internal extensions for fast peripheral access.
Analog-style volume controls for instant audio adjustment.
A 3-way toggle selector for multi-OS boot control — because one system is never enough.
At its core, a Raspberry Pi Pico handles all logic, boot management, and media control. Acting as the digital cortex of the interface.
Got the toggle switch working, so far....
JPEG Image - 2.58 MB - 10/26/2025 at 04:23
Preview
Boot selected with the 3 way toggle!
JPEG Image - 4.46 MB - 10/26/2025 at 04:04
Preview
3 way toggle From a Fender!
JPEG Image - 2.85 MB - 10/26/2025 at 04:02
Preview
  • 1 × Pi Pico v1
  • 1 × 3 Way Toggle Switch Went with the guitar version, just because.
  • 1 × Gesture Sensor APDS9960 Gesture sensor module
  • 2 × 3D Printed Custom Support Very stylish
  • 3 × Custom Acrylic Panel Laser cut acrylic panel
  • So frustrating!!!!!
    Pepa667 • 11/08/2025 at 22:30 • 0 comments
    So, at first I was trying to use a rotary encoder for the media control, after some rage outburst I remembered of some gesture sensor I have in a box here, tried with them, no success again – another rage attack... I was going to blame the cheap chinese components but, I'm sure it was all my fault...
    Now – as I think I haven't suffered enough – I've decided to try a gesture touchpad using an ATMEGA328P and some copper tape. Let's see where I can get with that now.
  • First Log Ever!!!
    Pepa667 • 11/01/2025 at 00:48 • 0 comments
    Damn, I was almost finishing to write and the power went down, so now I'll be quick...
    So, it's been a long time since I've worked on a personal project, and i is the first time I log one, I'll try my best.
    Well, the project is somewhat advanced. What is done so far:
    • Design of the module almost at final version
    • Module prototype supports and panels mounted on the table
    • rPi Pico boot selector is working
    • Changed the media control from rotary encoder to gesture sensor
    • Gesture sensor is working fine with the Pico
    You can have more information of how it works on my GitHub:
    https://github.com/Opus667/DeskNode
    And here are the photos so far, just for fun:
    https://github.com/Opus667/DeskNode/blob/100a10a60387d3d194090603f530029deadd7bcb/Log%20Photos/First%20Log/readme.md
View all 2 project logs
